Both my front turn signals were not working. The passenger side had broken plastic housing and the drivers side internal pins looked pretty bad. So I went to O-Reilly auto and picked up two 85881 sockets and new bulbs. I replace the sockets and the passenger side now works. But, the driver side still doesn't. I took a meter to the socket and probed the terminals. Nothing. When I put on the hazard flashers, the passenger side flashes, but the driver side does not.
Are there individual fuses to each light, or does one fuse control both front turn signals? The light on the dash flashes fast for the drivers side and regular on the passenger side.
Any idea where to look?
Reason: added more details.
Problem found! There is an 8-pin connector in the harness where this splice pack resides on the right side. I pulled it apart and found corrosion. The red wire had pulled out somewhat and was not making a connection. When pushed back in, the left turn signal works.
So, it's off to O'Reilly to find a new 8-pin male and female connector. Cut the old out and splice in the new.
