can i use c6 z06 headers on c5??
![](/forums/images/ranks/1k-2k.gif)
![](https://www.corvetteforum.com/forums/images/ranks/cf10.jpg)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
is that 100% sure that i can´t use this:
http://forums.corvetteforum.com/c6-p...-for-sale.html
thanks
Baezi
thanks
Baezi
![](/forums/images/ranks/5k-6k.gif)
Cruise-In VII Veteran
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
thanks
Baezi
thanks
Baezi
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
after 10,000 posts, I see a lot of people 'speculate'............
after 20 C6Z06's, I have figured out how to get those stock big **** pipes out of there(the 4 bolts are a pita)
![Big Grin](https://www.corvetteforum.com/forums/images/smilies/biggrin5.gif)
![Cheers!](https://www.corvetteforum.com/forums/images/smilies/cheers2.gif)
![](/forums/images/ranks/7k-10k.gif)
You should buy the headers, attempt the install and write a detailed summary of your experience with images.
Let the forum know how it works out for you...
![](https://www.corvetteforum.com/forums/images/ranks/veteran_navy.png)
Received 2,188 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
REMEMBER!!!!!! The C6 does NOT have the BAT WING oil pan. When the C6 header is designed, that is not taken in account.
Bill
Bill
![](/forums/images/ranks/3k-4k.gif)
The only thing I can think of on the C6Z headers that may make them different from the regular C5/C6 header is the dry sump oil lines, but that is just a theory.
Your best bet would be to call Kooks and ask them. However keep in mind that the mid pipe on the C6 is different on the C5 in how it attaches to the rear of the exhaust. C5 has a flange to connect, C6 is slip fit.
