Custom cam vs Off the shelf
Old Dec 10, 2009 | 11:38 PM
94brick's Avatar
94brick
Default Custom cam vs Off the shelf
So when one decides on a cam, as I am doing, I guess I have 2 options:
1) Get a custom cam from someone who can spec me a cam for my given set up or
2) Go with some of the tried and true cams that always get talked about (These are the ones that the vendors here on the forum have and typically give names to).
So here is my question... would I be better off with a cam that vendor X sells or getting a custom spec'd cam?
From what I can deduct, a cam from vendor X is a cam that has a proven track record and is known to give certain characteristics thus helping me know exactly what I am buying and should expect. The exact grinds of these cams come from what works and what doesn't, perhaps saving me the headache of figuring it out myself. However a custom cam is built for my exact set up. I would think this is a better way to go? But what is this a risk/benefit/plus of making a 1-off cam?
Old Dec 10, 2009 | 11:52 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
I would stick with something you know will make power. Unless you have someone that really knows what they are doing and will be able to grind one for you that will make power, I say better safe than sorry. Also the cams that everyone has/had can tell you how the cam does on the street and were the power band is. One off cams you will kinda know but really wont know until you get it in the car and drive it, but hey thats just my thoughts. I run a MS3 236/242 .609 lift and I can drive the car anywhere and it has a very very nasty lope at idle. Good Luck with the search
Old Dec 10, 2009 | 11:55 PM
lucky131969's Avatar
lucky131969
There is a ton of cam options out there, all with specific grinds, for SC, Nitrous, high compression N/A, etc. Since you have not stated what your goals are, what's important to you, etc.....it doesn't make sense to consider a "1 off" custome grind, when you don't even know if a vendors cam will fit all your needs.
Old Dec 10, 2009 | 11:58 PM
94brick's Avatar
94brick
Some folks around here and on LS1tech say that Patrick G is the man for cam specs. I pm'd him but so far no response. Bump for some more thoughts.
Old Dec 11, 2009 | 12:02 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
Custom grind; waste of time, energy and money for a street car.
Old Dec 11, 2009 | 12:05 AM
94brick's Avatar
94brick
So why do guys get custom spec'd cams? I have called several vendors from here and they all have "the perfect" cam for my set up. I am asking if there is anything to gain with a spec'd cam.
Old Dec 11, 2009 | 12:08 AM
94brick's Avatar
94brick
If mods are the factor I wouldnt have much. Heads/ headers + exhaust/ 4.10's / this from a 02 Z
Old Dec 11, 2009 | 01:27 AM
0331MARINE's Avatar
0331MARINE
Everyone you talk to is going to have the "perfect cam" for you. Look around on here for the dyno results and youtube for idle sounds and go with what you like.
Old Dec 11, 2009 | 11:41 AM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
just my .02
I think if you have an automatic then a spec cam might offer some advantages. As for a shelf cam compared to a custom cam, how would you ever know the difference unless you installed each and ran them on a dyno to compare? For a street car I would save the money. Buy some tunning software like HP Tuners and get the most out of your investment that way. There are lots of shelf cams that will make all the power you want.
Another thing to think about. Let's say a few years down the road you decide you want to change the cam. I don't see people wanting to buy someone's custom cam unless the price is discounted. Look at how fast some of the more popular grinds sell like a 224/224 or a 228/228 etc. They will bring ~$250 all the time.
I'm in the process of a HC myself and I just don't see the extra cost for a custom cam for a street car as a valued investment. Ok, I'm done
Old Dec 11, 2009 | 03:06 PM
MPM IV's Avatar
MPM IV
Cost should be the same. If you go with a proven combo you should have a good idea of what you're getting based on others results. I've had a custom cam and it didn't make much of a difference. From what I've read Pat G does a good job; someone has to pick the cam and if you trust his experience go with it.
Get the best heads you can, thats the critical factor IMO.
Old Dec 11, 2009 | 05:32 PM
94brick's Avatar
94brick
Good information
To Custom cam vs Off the shelf
