Time for new tires?
Old Dec 11, 2009 | 10:06 AM
kvozel's Avatar
kvozel
From: Centerville OH "If we weren't all crazy we would go insane"
CI 3-4-5-6-7 & 9 Veteran
St. Jude Donor '08
Default Time for new tires?
I've got an '04, original tires, 17k miles.
Tread is still good, just wondering how the EMTs hold up over time.
Old Dec 11, 2009 | 10:44 AM
jrose7004's Avatar
jrose7004
Sounds like they're still good.
Old Dec 11, 2009 | 11:23 AM
bhoch's Avatar
bhoch
how many years are the tires rated for regardless of tread? I am not sure I would want to be driving round on 6 year old tires on my vette.... but that's just me.
Old Dec 11, 2009 | 02:38 PM
kvozel's Avatar
kvozel
St. Jude Donor '08
That's my thinking as well. Around town no problem, but will be driving Route 66 next summer. I'll probably get new ones in the spring unless convinced otherwise.
Old Dec 11, 2009 | 02:39 PM
Dope's Avatar
Dope
Resident moron
Just make sure to inspect them for dry rot or anything like that.
Dope
Old Dec 11, 2009 | 02:41 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
you need new tires
Old Dec 11, 2009 | 06:42 PM
CatCam's Avatar
CatCam
As long as your not putting your car on the track or driving over 100 MPH I would keep your tires on. Heck, they are EMT's.....
Just check for any dry rotting.....
I'm in the same boat, 2004 with 7,600 miles with the original tires......
Old Dec 11, 2009 | 08:55 PM
GUSTO14's Avatar
GUSTO14
The Goodyear EMT's are notorious about getting noisy over time. The more heat cycles you put them through the harder the rubber gets and the noisier they get.
Are they safe to drive on? In my opinion, yes.
Will you notice the car is quieter (along with better grip) if you replace them, absolutely...
Your call...
Good luck... GUSTO
Old Dec 11, 2009 | 09:36 PM
K RIPPER's Avatar
K RIPPER
time for tires,undecided what to buy,did some research, it was pointed out that tires are not plain rubber but a number of compounds which over time deterioate rendering your tires ineffective for it's intended use.From the information I gathered tires are very effective for four years from date of mfg.the chemical compounds deterioate after that they get hard and although they look like the same tires maybe with decent tread, rest assured they are NOT the same tires you had when new.as previously mentioned if no rot or visible defects should be absoulte safe to use, if it were my "B" OR "C" car I wouldn't give it a second thought but corvettes are special cars and thus special treatment.
Old Dec 11, 2009 | 11:28 PM
Oldvetter's Avatar
Oldvetter
The tire industry wanted 6 years as life of tires, but could not get government agreement. Your tires ARE safe. I would run to about 10 years. Check sidewalls and in between treads for cracking. Don't mistake belts between treads for cracks. If the care has been garaged (out of sun) tires will last much longer.
Old Dec 12, 2009 | 12:20 AM
pcbunn's Avatar
pcbunn
Call me cautious but I just changed out my '01 Goodyears with 22k for new Michelin PS2's. Nine year old tires just give me the *******, now I am much happiness!
Old Dec 12, 2009 | 12:48 AM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
are you kidding me , 72 k on my 04 and my 5th or 6th rear set will be here monday . maybe 3rd on front .
Old Dec 13, 2009 | 12:02 PM
Dragon Daddy's Avatar
Dragon Daddy
I have done a little research on tires and the 'safe' life of a tire is about six years. Things to consider:
1. How old were the tires when they were installed?? If they are original, then they should have been pretty fresh. To determine when they were 'born' reference this site:
http://www.tiredefectslawyer.com/aged-tires.php
2. How do you drive?? If you are only using the car to drive to the local grocery store, then your risks are minimized. However, if you drive at high speeds (observing all local speed limits, of course) for prolonged periods of time, then your risks are increased.
3. What type of driving performance do you desire?? Generally speaking, newer tires are softer than old (the compound has not degraded), so they provide greater traction.
Cheers.
Old Jan 11, 2010 | 09:59 AM
CVetteLuver's Avatar
CVetteLuver
The last digits of the DOT on my tires are "M620". Does that mean month of June, year 2000?
Old Jan 11, 2010 | 10:31 AM
SaberD's Avatar
SaberD
i have heard that you should replace them after 5 or 6 years reguardless of the tread condition. i would bet they can last up to around 7 years though. after that, i would definitely replace them.
Old Jan 11, 2010 | 10:59 AM
CVetteLuver
I agree and would rather be safe than sorry. I'd just like to verify the age of my run-flats before plucking down the big bucks for a new set. I brought my 2000 used about a year ago.
Old Jan 11, 2010 | 11:34 AM
Dave concrete's Avatar
Dave concrete
Don't be the next bad story,its time for new tires.Plus you won't believe how bad they are to you put new ones on.I replaced mine at 10,000 miles with plenty of tread they were just hard and traction sucked.
To Time for new tires?
Old Jan 11, 2010 | 06:25 PM
MikeV's Avatar
MikeV
Mine are 8 years old with 41K on them and the side walls still look like new. I plan on changing them at around 45K. I don't think I would trust them at 150 but they are fine for normal driving.
Mike V
Old Jan 12, 2010 | 11:36 AM
GettnBetter's Avatar
GettnBetter
I dumped those rock hard, low grip, squeaky EMT runflats several years ago and put on non-runflat GoodYear F1 GSD3's. They fit the C5 perfectly. WOW! What a difference, you can actually use the throttle to steer consistently, no squeals around slow turns or on parking lots and the ride is incredibly smooth. Also, wet handling is the best I've felt, braking, launching or sweeping turns. They are super quiet too, low speed you can't even hear them roll, even at elevated freeway speeds they are silky smooth.
I drive my Vette a lot. I have 40k+ on the fronts and a new set in the garage just waiting, the rears only last me about 25k but I have a lead foot.
Old Jan 12, 2010 | 11:50 AM
Chuck A's Avatar
Chuck A
St. Jude Donor '08-'09
Mine are 10 years old, and have 39k on them , yea i also plan on changing them real soon
