Header Gasket Install...
Old Dec 12, 2009 | 11:38 AM
Chrohm's Avatar
Chrohm
Default Header Gasket Install...
I need new header gaskets, got one leaking...
If i buy the gaskets, how much would someone charge to install?
Old Dec 12, 2009 | 12:16 PM
waddisme's Avatar
waddisme
It takes me less than an hour to get mine loose and back together. I also have my AIR hoses removed which helps alot! You can do it your self - it just takes different lengths 10mm sockets and some patience. The best tool I use for that is the thumb ratchet. Works great in tight places. Good Luck.
Old Dec 12, 2009 | 01:28 PM
Tech's Avatar
Tech
A shop? 1-2 hours labor assuming it's stock.
Old Dec 12, 2009 | 02:03 PM
Slow Z06's Avatar
Slow Z06
come over to the house. Ill help ya do it
Old Dec 12, 2009 | 06:37 PM
Chrohm's Avatar
Chrohm
you in longview or houston? I guess houston isn't that far
Old Dec 12, 2009 | 07:05 PM
Slow Z06's Avatar
Slow Z06
Houston
To Header Gasket Install...
