Me again....T.B.????
Old Dec 12, 2009 | 07:06 PM
2079's Avatar
2079
Default Me again....T.B.????
Well this is probably my last post to finalise my H/C mods.
1 - I did polished the ports in my new LS-6 heads
2- selected a cam..VRX 2 , very popular from all the sugestions I received.
3- Have the PAC 1518 V springs ,IE ;if Vet N. as these I cant go wrong
4 - Got some Ford 30lb. injectors again recommended by B.C.
5 -Have all other stuff.. Y T rockers , LS 6 intake, 3.42 ,yank 3200,etc.
6-.....Now, do I need to get a bigger T B or polish/ port mine ?? if so what will be the benefits if any ?
7- did I forget something ?
Thanks ....Lucien
Old Dec 12, 2009 | 07:59 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
I don't see any need for a bigger throttle body but if you are porting it yourself be careful. It's easy to get carried away and go too far creating idle problems.
Old Dec 12, 2009 | 08:12 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
If you haven't put it together ywt i would install the LS6 valley/PCV --If you would look inside your old manifold with a flashlight you'd be shocked to see how much oil is in there---Not good for clean combustion---installing the LS6 valley helps--but in addition some sort of catch can or coelesatiing filter as well---
I agree a larger T-body is a waste---and i wouldn't touch it myself either--you can really mess it up easily---send it off to Shaner to have it ported/polished
AND a tune is a MUST after you get it done--
http://s2performance.net (for shaner site)
To Me again....T.B.????
