Need opinions on heads cam and spray setup
![](/forums/images/ranks/100-500.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Im looking to do some modding on my 02 Z06 this winter. Looking for some good heads and cam setups that work well with spray. Something like AFR 205 or 215's. Im open to suggestions. Probably gonna be spraying 150 wet through a nozzle. Also I'm a firm believer in bigger is not always better, I believe tony mamo had a thread where a customer made some rediculous #'s on some 205's just dont know how well that setup would respond to spray. I will be doing all the work myself, and my current mods are Fast 92, Ported LS2 TB, Halltech intake, Spec 3+, hardened output shaft. Car is going to be about 50/50 Street, Strip may cruise it every once in a while (1-2 days a week max) but prepairing for race season.
Former Vendor
Afr or trickflow heads are proven to perform. PM me more about your power goals and i can help you pick out a cam.
![](/forums/images/ranks/11k.gif)
If you are considering AFR's, shoot a PM straight to Tony. He can advise on the AFR's for the setup you are considering. Also, there are two new heads (one is larger then you need) being introduced shortly by AFR.
I'm not set on afr's might have to go with some prc's just depending on my money after christmas. also forgot to mention i also have lg streets, no cats.
