timing tuner install ?
Old Dec 16, 2009 | 08:31 AM
dogboy's Avatar
dogboy
Default timing tuner install ?
Anyone install one of these? I have to plug it into the crank sensor (CS) outlet above and towards the rear of the starter. I know I will have to drop the started to get access and I can get to the 2 bolts that hold it up with the long tubes in place.. I wonder if I can unbolt the starter and pull it foward and let it lay on the headers just enough to gain access to the CP plug. After I plug in the cable I can than put the 2 starter bolts back in, hook up the battery cable and be done. I'm trying to avoid dropping the exhaust and header. Can it be done this way
