fuel leak
Old Dec 16, 2009 | 06:09 PM
vet85's Avatar
vet85
Default fuel leak
hello gotta good friend who has a 98 -50k mile car he call me today and said he is getting gas on the ground next to the left rear ...any suggestions as to what might b on that side of the car by the left wheel that may b leaking .....thank u ....
Old Dec 16, 2009 | 10:24 PM
byronhunter's Avatar
byronhunter
Check the Fuel Filter connections.
Old Dec 16, 2009 | 10:30 PM
vettekidc5's Avatar
vettekidc5
Sending unit gasket. The sending unit bolts to the rear of the Left fuel tank on the side. Accessed by a removable aluminum cover.
These gaskets are prone to leaking and GM has issued a revised gasket with new bolts that comes as a kit
Old Dec 16, 2009 | 10:54 PM
Mark-44's Avatar
Mark-44
Replaced the fuel filter on mine...no more leak. Beware the gasoline was leaking on the exhaust pipe on mine.
Old Dec 17, 2009 | 12:09 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Normally this is a fuel filter connection developing a leak. Its fairly common to find. However, its critically important that he stops driving the car immediately and fixes it right away. The filter is right over the exhaust pipes and he doesn't need the car to go up in flames.
To fuel leak
