Was at the track this last weekend and had a problem with the brakes on either the front....or rear (it was hard to tell) locked up without any indication anything was wrong.
Immediately after the problem I got the service ABS?TC/AH on the dash.
Went through the codes and these are the ones that came up.
All are history codes.
P1575
C1248
C1255
C1267
Any info on where to start would be greatly appreciated.
I forgot.
2003 Z06
Brembo brakes all the way around
Reason: More Info
P1575
C1248
C1255
C1267
I forgot.
2003 Z06
Appears you had a malfunction involving the EBTCM (C1255), Brake Pulse Module(C1248) & brake switch circuit(P1575). First, reset/erase the above history codes, & see if any return with a C suffix= "Current" code showing....could be your EBTCM has gone/is going bad ... lemme know...I got a guide for checking it out.
I just had to replace my EBTCM, made all the problems go away!
You may be able to have yours repaired at www.absfixer.com Sometimes the circuit board within there cracks or the solder joints crack and need to be repaired! Mine was beyond repair this time.
