Right front tire going flat?
Old Dec 17, 2009 | 04:23 PM
65convt's Avatar
65convt
Default Right front tire going flat?
Yesterday I took the wifes 98 out for a ride. As soon as I got out of the driveway the RT Front tire flat was flashing at me. The Rr, Lr, and left front said they were low. I know temp changes will effect air pressure.
I stopped and put air in the tire and inspected it. Found nothing in the tire. This morning it was reading flat again. Could the o-ring on the sensor be bad and cause it to leak out.
Any ideas!
Old Dec 17, 2009 | 04:33 PM
87SAM's Avatar
87SAM
Yes the o-ring could be leaking, there is torque spec but I do not remember it right now. Could also be leaking around the bead of the rim or a small nail you can not see. Spray some soapy water around and see if you can find it.
Old Dec 17, 2009 | 08:30 PM
TEXHAWK0's Avatar
TEXHAWK0
Any ideas!
When you say it was reading "flat", does that mean zero?
Did you check the pressure with a gage, or just put air in it to get the message to go away?
Old Dec 17, 2009 | 08:49 PM
jrose7004's Avatar
jrose7004
The o-ring certainly could be leaking also you might have a crack in the wheel!
Old Dec 17, 2009 | 11:14 PM
c5blkvetteguy's Avatar
c5blkvetteguy
Check the inside bead part of the wheel for a crack. If it is the o-ring, (not a true o-ring) they dont give them away. I think I payed $6.00 each....for a little piece of rubber!
Old Dec 19, 2009 | 06:02 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
I played with a cracked wheel for three months. Replaced the O ring etc. Finally took the wheel off and still could not see anything.
Tubbed it in a tub of water and found a hairline crack in the wheel.
Ordered one from Toms House of wheels and had it in a week.
Kept the old one as I had it repaired.
Old Dec 19, 2009 | 11:22 AM
rws.1's Avatar
rws.1
You can buy the o ring at Home Depot for under 50 cents.....
Old Dec 19, 2009 | 11:40 AM
rws.1's Avatar
rws.1
The "o" ring is a #9 at Home Depot
see this my post in this thread from the archives for a DIY on sensor replacement and torque specs....
http://forums.corvetteforum.com/c5-g...-new-rims.html
Old Dec 19, 2009 | 12:28 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
My son is having this issue with the '99 that I gave him last year. The right front keeps losing pressure. In his case, apparently the wheel itself is leaking on the bead seal from corrosion taking place. I doubt there's a way to fix this as I'm sure no wheel expert, but it could be what's up with the OP's wheel too.
Old Dec 19, 2009 | 02:09 PM
byronhunter's Avatar
byronhunter
dgrant, sure you can fix it! It's called Sandpaper.
Old Dec 19, 2009 | 06:32 PM
dgrant3830's Avatar
dgrant3830
I'll pass that onto him. I'm here in S. Calif enjoying 84 degrees and he's in Virginia buried in snow...
Old Dec 21, 2009 | 01:05 AM
65convt's Avatar
65convt
Thanks for all the responses.
As soon as this damn snow melts I'm taking it to my tire guy and checking it out.
Can't understand how it would have a crack. It doesn't get driven much. Maybe 900 miles a year. last few times out I had no inflation problems and didn't hit any hard bumps and no potholes.
Thanks again,
Rick
Old Dec 22, 2009 | 11:37 AM
jedblanks's Avatar
jedblanks
discount tire usually has the orings on the shelf for free (if they are mounting), so if you take them the tire to fix the "flat" they will replace it, probably for free.
Chrome rims sometimes leak around the bead. The problem can be the bead of the tire (which installers sometimes break) or the rim (corrosion inside).
Soapy water will find the leak, or you can have a shop dunk the tire to find it.
Old Dec 26, 2009 | 08:15 PM
bighank's Avatar
bighank
Default Had same symptoms pulled wheel found hairline crack on inside bead
Pull the wheel. Put water in the bead on one side then another. If no bead leak put in a tub of water and slowly rotate tire until you see bubbles. Do this with enough air in the tire. 35-45 lbs. You will find your leak. Depending on where it is take the appropriate action, tire stem core, o ring, or bead leak. I had to replace the rim. Then had a bad valve core. Should not hve ANY bubbles. BIGHANK
Old Jan 1, 2010 | 08:45 PM
MG RED 99's Avatar
MG RED 99
Another thought besides the sensor o-ring is if you use aftermarket valve caps with little o-rings in them. Sometimes the o-ring gets pushed into the stem a bit and allows the tire to deflate. I stopped using those types of caps for that reason. I have also had a slow leak only during the cold months, and tightening the sensor nut helped to slow the leak but not completly. Since I store the vette in the winter I just put air in it once in a while. It doesn't leak at all during the summer months. I do need to replace the o-ring one of these days.
Old Jan 1, 2010 | 09:22 PM
DansVette's Avatar
DansVette
Is this another wonderful GM issue ? I have NEVER had an issue such as this until I got my '98. Both of my rears keep going flat. Not a tire problem according to my tire dealer. One dealer in fact told me I needed new wheels. Never have I ever had a wheel somehow go bad without being in some sort of accident.
Of course nothing would surprise me at this point.
Anyone truly surprised that they needed to bailed out by the government ?
Old Jan 2, 2010 | 12:30 AM
Bill Dearborn's Avatar
Bill Dearborn
99+% of the people owning C5s have never had this problem.
As others in this post have said you should look at the O Rings. If they are the originals they may have decayed back into the original compounds they were made from by now. You should also check the beads where the tires seat. You could have a leak there as well. Maybe some dirt got between the tire and the wheel when a tire was mounted. Tire jockeys aren't the brightest bulbs in the store.
Bill
To Right front tire going flat?
Old Jan 2, 2010 | 06:19 AM
Carcass's Avatar
Carcass
My right front tire began slowly losing air about a month ago.
Upon close inspection,I found a small piece of wire had punctured the tire,between the tread.
I ran over the wire,but somehow,it must be GM's fault
Also,the gas gauge will slowly move toward "empty" during the week,and the only fix I've found for it is to put more gas in the tank,or leave it sit in the garage,and don't drive it.
Obviously another GM issue.
Old Jan 2, 2010 | 08:30 AM
realvc's Avatar
realvc
My right rear tire leaks about 1lb every two days. It started this after buying new tires. The tire shop found my leak at the bead, the chrome is flaking inside the rim at the bead. The rims were on the car when I bought it. They are the chrome C6 Z06 style made in China. I drive the vette mostly on weekends and keep an eye on the tire pressure.
Now I'm trying to decide if I should replace the one rim, just the rears or get a whole set. Such is life. Until then I air it up before I leave the house.
So far it has never lost enough air in one day to show up on the DIC
It is amazing how such a simple thing like an air leak can be a big problem.
Old Jan 2, 2010 | 08:51 AM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
You have a 1998 and the Tire Pressure Sensors (TPS) are likely the originals. If all else checked out OK and you're not leaking air, then perhaps the internal TPS battery may have died or become weak to the point where its giving faulty air pressure signals. Replacing a 1997-2000 TPS (Part #10438853) Battery. The battery is a CR2477N.
