oil catch can question
Retarded timing means loss of power.....do you see where I'm going?
This is typically less of a problem when it comes to smaller engines, as total blowby flowrate past the PCV valve is much less, meaning oil dropless in that blowby is also reduced.
More info can be found here:
http://www.conceptualpolymer.com/PCV...oval%20102.pdf
http://www.ls1tech.com/forums/genera...outing-ok.html
I normally burn a quart during a two day event. It is keeping a third of my total oil consumption from going down the intake.
I blame a high percentage of the rest on my excessive oil temps. That's my winter project.
I get on it once in a while
The other thing to remember is that even though the dipstick shows no loss, the oil that is burned up is displaced by moisture, especially during this time of year when temperature swings are wide and frequent.
What is considered an oil consumption issue ? John Juriga , Assistant Chief Engineer for Gen3 Engines at a press conference at Irwindale Speedway
2002 stated that using a quart oil in 2000 miles or less was a consumption issue. Generally the offical GM detemination of oil consumption was of course left to individual dealerships and how persistant the individual Vette owner was.
Oil consumption is an issue with these Gen 3 engines in particular applications ,generally manual transmissions and owners with aggressive driving styles. This is well documented.
The more aggressive Napier scraper ring and increased ring tension (9 to13 lb) did help the majority. But it was a band-aide at best as the actual problem is with the 5300 mid size utility block's siamesed cylinder coolant passages. With the only coolant passing between cylinders (water jacket) thru small 20mm passages at the top of the cylinders , the cylinder bores developed hot spots that caused distortion (out of round spec.) that the OEM piston rings ( with the less aggessive Napier face and less ring tension) could handle. Add to that the loose cylinder bore machining tolerances and cylinder bore taper issues. ( All these issues are documented and were addressed with the Gen4 LS2 engines)
If you are a conserative driver with an automatic transmission , you less likely to experience high oil consumption ( blow-by).
The negative affects of oil consumptions are (1) carbonizing cylinder heads , pistons & rings, valves , spark plugs.
(2) Emissions componet contamination i.e. O2 sensors, Cat converters that result in decreased performanmce and premature componet failure.
(3) Reduced performance by screwing up the air/fuel mixture ( dependent on how much oil/moisture crankcase vapor( blow-by) is drawn into the throttle body/intake manifold).
In theory all the oil catch can does is route this oil/moisture fouled, comtaminated air thru a sparator/ baffle back to the engine to be burned. In practice most oil catch cans are not installed properly for optimum effectiveness, but still offer a variable % of success. Then add the fact that not all oil catch cans are 'created equal' in design. See Dave68 website.
My three (3) C5es (also my '87 Grand National, Mustang GT350) do not use any noticeable amount of oil between 3000 mile (once a year) oil changes but like any insurance policy I encourage Gen 3 owners to install an oil catch can.
That's what a catch can is meant to prevent.
