abs pump advice needed
Old Dec 20, 2009 | 04:09 PM
glowworm_76039's Avatar
glowworm_76039
Default abs pump advice needed
I have a 2000 a4 with active handling. I have read through the stickies and am unable to find anything about the abs pump itself. My local shop tested my pump and it is bad. Is there an easy fix for this?
Old Dec 20, 2009 | 04:20 PM
87SAM's Avatar
87SAM
You need to check and post the codes to help determine what the problem is. If the pump is bad, it needs to be replaced.
Here’s how to check codes.
http://www.c5forum.com/ayc/dtcdic.php
Old Dec 20, 2009 | 04:43 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The EBTCM opeates the pump. Thees a connector on the bottom od the main connector housing for the pump. Just disconnect it and apply 12 VDC to it and see if the pump runs. If it does, it NOT bad.
Hees a pictue of the BPMV and EBTCM
You can see the moto connector in this picture:
BC
Old Dec 20, 2009 | 07:18 PM
glowworm_76039
I've tested the pump with 12v and it's bad. Has anyone rebuilt one of these or is there an easy repair for a pump that doesn't work. I'm trying to avoid buying a new pump...
Old Dec 20, 2009 | 10:00 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The BPMV is sold as an ASSEMBLY and no repair parts are available. If you can get one from a salvage yard or private sale, that would save you some money. Other wise,,,call Gene Culley www.gmpartshouse.com and get a new unit.
If yours is truely bad, rip that bad boy apart and see if you can salvage it.
BC
BC
Old Dec 20, 2009 | 10:30 PM
csc67's Avatar
csc67
Bill,
I have been troubleshooting a Code 1243 (Stalled ABS Pump) in my YR 2000 vette for a while.
If I understand your statement correctly ("Just disconnect it and apply 12 VDC to it and see if the pump runs. If it does, it NOT bad"), and my BPMV runs with 12 volts, then it must be a ground or the EBCM.......Right
glowworm_76039: There is another forum member (sjbrothers) is looking for broken BPMV's so he can try to find a way to repair them. If you find out yours is broken and you want to donate it to his science project, please send him an e-mail
Old Dec 20, 2009 | 11:00 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Some people NEVER drive their car to the limits that it was designed to handle and don't cycle anti lock brakes or active handling system. . Nothing wrong with that except, the BPMV Pump can become stagnant and stick from non use-age. If you apply an external voltage to the pump and get it to spin and free up, it may resolve your issue.
When ever I drive the car in wet weather, I find a safe place to apply the brakes hard enough to activate the anti-lock and or active handling systems. What better way to get a feel for how the car feels in those conditions. Wet weather allows system activation without excessive strain on the suspension or excessive tire wear.
Yea,,,I find times on normal driving conditions that reach the limits also.
Cycle the pump a couple of times and see if that helps. What ya going to loose?
BC
Old Dec 21, 2009 | 09:35 AM
sjbrothers's Avatar
sjbrothers
Originally Posted by csc67
Bill,
My 2 cents worth: I found that just applying 12 volts did not fix the problem. The pump runs but unless you exercise the valves in the BPMV you will not clear up the problem. I found that changing the brake fluid and using the pump to do that has removed the C1243 problem...at least for now.
Old Dec 21, 2009 | 04:33 PM
glowworm_76039
Thanks for the advice. I'm going to pull the pump next weekend and try to tear it apart and see if I can clean it up and try to make it work. If I come up with a way to make it work I will post what I came up with...
Old Dec 21, 2009 | 05:10 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Please take pictures of the disassembly. The inside of that BPMV is a mystery as no ones ever documented it dissection.
Old Dec 21, 2009 | 07:24 PM
The Wrench's Avatar
The Wrench
Bill, are those pics of the ABS from a pre-2000 car?
I understand the early C5's had the ABS unit mounted near the rear axle, but the 2000 has it under the power steering in the engine compartment.
I had the 1243 code (stalling/dragging pump motor) in my 2000 last year, and had to partially disassemble the ABS unit to get to the proper contacts to "excercise" the pump motor. It's been awhile so I don't remember all the details (pin #8 I think) but we documented it here in the archives.
After several short 5-second runs, the motor amperage dropped significantly, lossening up quite a bit.
However, a year later, with no use of the aBS in driving, I occasionally get the code again. Gotta drive that thing harder I guess.
DG
Old Dec 21, 2009 | 07:41 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The 97 and early 98 C5's had rear mounted EBTCM/BPMV: In late 98, they moved it to the front. Here is what they look like in the rear:
The late 98 up to 2000 have EBTCM that look some what different than the one in my pics. The one in my pictures is the 2001+ unit.
BC
Old Jan 18, 2010 | 03:04 PM
glowworm_76039
Quick Update-
I work at a car dealership, and this is the busiest time of our year, so it will probably be mid february before I attempt to take the pump apart.
I'll keep you posted...
To abs pump advice needed
