LS1 pistons.....
Old Dec 21, 2009 | 10:40 PM
LT1vette's Avatar
LT1vette
Default LS1 pistons.....
Anyone know if the 99FRC car came with cast pistons or forged pistons?
TIA
Old Dec 21, 2009 | 10:56 PM
torkman15's Avatar
torkman15
TIA
I'm pretty sure they are Hyperutectic.
Old Dec 21, 2009 | 10:59 PM
LT1vette's Avatar
LT1vette
Are the ZO6's forged?
Old Dec 21, 2009 | 11:18 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
Hypereutectic actually refers to the material used and not the manufacturing method. Both LS1 and LS6 pistons are hypereutectic forged pistons.
Old Dec 21, 2009 | 11:46 PM
lucky131969's Avatar
lucky131969
Wow, forged pistons are stock in an LS1 and LS6?
Old Dec 21, 2009 | 11:57 PM
Mark C5's Avatar
Mark C5
Lucky, after my last experience relying on a manual I'm a little gun shy, but that's what my reference tells me. I'm using "How to Rebuild GM LS-Series Engines" by Chris Werner. Unfortunately I know he does have some errors in the book but I don't think he's mistaken about the pistons.
I do know I'm correct about the meaning of hypereutectic.
Old Dec 22, 2009 | 12:02 AM
lucky131969
A hypereutectic piston is a cast piston with a high(er) silicone content. It is not a forged piston. While hypercutectic pistons will take more abuse than your base cast variety, there is no substitute for forged pistons. If you notice, forged pistons are in every motor built for high performance, FI, etc. I'm sure many of us, including myself, wish the LS1/6 came from the factory with forged pistons and rods.
GM finally got it right with the FI LS9, forged pistons and rods.
Old Dec 22, 2009 | 12:15 AM
Mark C5's Avatar
Mark C5
I have to disagree with this as a blanket statement. A hypereutectic piston can be cast or forged. Hypereutectic only refers to the material used, not the manufacturing method.
If you are sure the LS pistons are cast I'll defer.
Old Dec 22, 2009 | 12:36 AM
lucky131969
Most factory hypereutectic pistons have a silicone percentage of 16-19. Alloys used for forged pistons have much lower percentages of silicone 11 or lower.
You don't have to believe me, I'm sure there is hours of reading on the subject on the net.
As long as I know what I have, that's all that matters:
My 99- hypereutectic
My 65- Forged
Old Dec 22, 2009 | 12:49 AM
LT1vette's Avatar
LT1vette
My 65- Forged
Hi....So we are getting close!!!!
On a 99 FRC car with a factory stock engine. Are the pistons the same quality as was installed later in the Z06 engine...........
TIA
Old Dec 22, 2009 | 12:55 AM
lucky131969
TIA
I'll let you be the judge.....I'm out....
http://www.gmperformanceparts.com/En...4322&engCat=ls
http://www.gmperformanceparts.com/En...1268&engCat=ls
Old Dec 22, 2009 | 01:16 AM
LT1vette's Avatar
LT1vette
That seems to be pretty definitive!.....same pistons..interesting.
I'm thinking of adding NOS to my 99 and was cautioned because of the quality of pistons. That they were as not as good as the Zo6 piston, hence would not take the abuse....
Thanks for the help
Old Dec 22, 2009 | 08:49 AM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
There are a number of reasons why a manufacturer would choose to use hypereutectic over forged. In the case of the LS series engines, the need to keep tight bore to piston clearances for reduced vehicle emissions is one of the key reasons. Forged pistons typically have a lower percentage of silicon and require higher bore to piston clearance due to their higher coefficient of thermal expansion. The LS series engines with their short skirts, reduced mass and deck height make it a challenge to control piston type noises. Keeping tight piston to bore clearances and a low coefficient of thermal growth are a must to negate cold piston type noises. The LS9 has forged pistons and the only LS engine that I’m aware of that does.
Old Dec 22, 2009 | 11:28 AM
~Josh's Avatar
~Josh
Banned Scam/Spammer
I thought the LS9 shared the same Ti connecting rod as the LS7?
The piston is forged, but the rod is titanium.
Old Dec 22, 2009 | 11:51 AM
lucky131969
.....forged titanium......
http://www.corvetteactioncenter.com/..._pursuit5.html
Old Dec 22, 2009 | 11:57 AM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Ohhh... gotcha.
Thanks.
To LS1 pistons.....
