Adding RCA inputs to sound system.
Old Mar 3, 2002 | 01:01 AM
pip's Avatar
pip
Default Adding RCA inputs to sound system. ** MOVING TO AUDIO FORUM - SORRY **
I've been lurking on these forums for a couple of weeks now, and have just bought myself a used 2002 A4 Coupe in torch red. Thanks to the posts here I have many links to useful suppliers and instructions for installing a Donaldson Blackwing. Looks pretty straight forward. Thanks guys!
However, I have a portable MP3 player and want to use that in the Vette, so I need an external feed into the sound system. I'm sure the head unit can accept an external source as the CD changer is an option. How could one hook in RCA connections to the head unit as an alternative to the CD changer?
Assuming some kind of wiring adjustment is required will I need to remove the head unit? Is this an easy task? I'm not too confident I wouldn't screw this up, can anyone recommend someone in the Denver area to fix this up for me?
Thanks!
[Modified by pip, 3:20 PM 3/3/2002]
Old Mar 3, 2002 | 01:30 AM
BadAttitude's Avatar
BadAttitude
Default Re: Adding RCA inputs to sound system. (pip)
Try the Audio Forum, you'll get a much more directed set of responses. Well, you'll get *A* response. :jester
~ BadAttitude
