2003 Electrical Problems
Old Dec 23, 2009 | 08:11 AM
woodvette03's Avatar
woodvette03
Default 2003 Electrical Problems
I am having electrical problems with my 2003 coupe. At random, the car will not start. It is completely dead. No lights, won't crank, nothing. It can be jump started to get it going. It is not the battery. Had 2 different batteries in it and they tested okay. Alternator is charging when driving. I hooked up an ammeter to the battery and there seems to be a drain of 0.50-0.60 amps which I understand is high. Pulled fuses and relays but could not find problem. Anyone have any ideas or experince this problem??
Thanks.
Also the other day when this happened and I jump started to get going, the headalights, radio, and climate conrtol would flicker on and off at random.
Old Dec 23, 2009 | 01:15 PM
BigGun's Avatar
BigGun
Thanks.
Start with checking your connections at the battery and starter. Make sure they are clean, tight and the cables themselves are in good condition. Be careful around the starter...that wire is hot. Might be a good idea to disconnect the battery before wrenching around down there. Don't over look the grounds.
Old Dec 23, 2009 | 01:23 PM
lucky131969's Avatar
lucky131969
For clarification, the lights flickered after the car was started, or before the engine was running?
Old Dec 23, 2009 | 01:39 PM
65GGvert's Avatar
65GGvert
Do what he said. Check the red wire from the battery to the starter very carefully. It loosens and can actually burn the insulation around the post. Post back what you find.
Old Dec 27, 2009 | 08:25 AM
woodvette03
The lights, radio, and heater would flicker on and off after I got it jump started while I was driving.
Old Dec 27, 2009 | 08:43 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You need to do a real close inspection of EACH battery cable terminal end. There fairly complex and have a lot of unseen connections and joints. The rubber protective boot hides a lot. Under the boot is a crimp connection. Roll the boot back and make sure that it not, loose, corroded or burnt.
Look for corrosion where the bolt goes thru the battery terminal end. I flush out mine with brake parts cleaner. You will be amazed at the crap that comes out if its corroded..
The rubber boot can also get pinched between the battery terminal and the terminal connector that connects to the battery.
The battery terminal bolt needs to be tightened to 11 ft/lbs. If you can move the battery cable terminal on the battery when its tightened,,something is wrong and most likely your issue.
Once the battery terminals are good, go right to the starter and look at the solenoid:
Also check the battery ground wire on the engine block near the starter. It must be clean and tight.
BC
Old Dec 27, 2009 | 08:55 AM
rws.1's Avatar
rws.1
Good advice from our C5 electrical guru.... Bill Curlee
To 2003 Electrical Problems
