Let me try this one more time
Old Dec 23, 2009 | 10:49 AM
Y-Fear's Avatar
Y-Fear
8th Gear
Default Let me try this one more time
Before I tow to dealer, I thought that I would give this one more shot.
Tab in key cylinder broke off on 2003. Tried to bypass, but apparently I am doing something wrong. Had to use four resistors to match #2 key 523 ohms.
I purchased a new key cylinder, and thought that would solve the problem, it didnt. Went back to the chevy dealer where I got cylinder, they say I have to tow it in to reset computer after replacing key cylinder(doesnt make sense).
Towed car home, I havent been able to retrieve codes. Tried to jump start due to battery discharge nothing. Tried 30 minute relearn may not have enough charge on battery(tried portable jump starter to keep voltage up didnt work). I hope that I am doing something wrong in the bypass procedures.
The dealer claims that it will only be 98 dollars to reset system. Not bad but it could turn into needing xy and z. So before I tow it wanted to do my best.
Questions: 1. Does the dealer have to reset something that I cant do
2. What I'm I missing in the steps to do vats bypass.
Obviously I need the vats bypass for dumbies method-exact wires, how resistors connect etc.
3. Should I purchase the vats bypass resistor discussed on this forum could that be the issue. And why can I not find one for the c5. I assume that as long as its for a number #2 it doesnt matter.
Thanks, Will check any responses after I get to clients home.
Old Dec 23, 2009 | 06:45 PM
byronhunter's Avatar
byronhunter
If your problem is just the VATS reader contacts in the Ign Lock cylinder, it is a simple mod to bypass. Google "vats bypass." If you have other problems, just doing that mod will not cure all ills.
Old Dec 23, 2009 | 10:15 PM
Y-Fear's Avatar
Y-Fear
8th Gear
Its running, thanks guys.
You're right it appears to be the battery.
After putting everything back together without resistors, I tried to start it.
For the first time it tried to turn over, so I jumped it and it started.
I am still wondering why it didnt start when I tried to jump it a couple of days ago.
Maybe I had the bypass set up wrong or something else disconnected.
I will get the battery tested and replaced (I hope that's it).
I feel like going by the chevy dealer and asking them to show me what they were talking about as far as resetting the car after a key cylinder replacement.
Anyway I'm Glad I towed it home and got on corvette forum instead.
Old Dec 24, 2009 | 12:26 AM
striper's Avatar
striper
It is amazing the multitude of weird problems these cars can have from a low battery. Last winter I had my car apart for several weeks while doing some work to it and the battery had run down from sitting so long. When I tried the first time to start it, the noises and flashing lights, etc. were incredible. I thought maybe I blew something up. Charged the battery with a battery tender (took a long time) and when I tried to restart it, it ran perfectly like nothing wrong had ever happened.
To Let me try this one more time
