Warming Up Engine
Old Dec 23, 2009 | 08:13 PM
Choreo's Avatar
Choreo
Default Warming Up Engine
How important is it to let the engine warm up before putting the car in gear?
(1) Does is really matter?
(2) Just in winter?
(3) How long or to what temperature?
(4) Does it affect the transmission/rear end?
Old Dec 23, 2009 | 08:25 PM
01_torch_red_vette's Avatar
01_torch_red_vette
putting it in gear isnt too big a deal if its not warmed, just keep the rpms low and granny it if you start driving it before its warmed up. you are more likely to damage your valve springs if you rev it to the moon when the engine is still cold
Old Dec 23, 2009 | 09:10 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
I always warm up to 150 deg oil temps before going WOT on my Patriot Gold springs
Old Dec 23, 2009 | 09:34 PM
jrose7004's Avatar
jrose7004
I just let the oil pressure come up before I put it in gear and drive off.
Old Dec 23, 2009 | 11:01 PM
Carcass's Avatar
Carcass
I usually let it run about 1/2 a minute before driving ,then I grandma it till oil temp gets to about 140.
The tranny is happier when it warms up a bit,too.
Old Dec 24, 2009 | 01:43 AM
memphis_vette's Avatar
memphis_vette
in the summer i dont warm my car up since it gets up 120 here in cali but in winter i let my car warm up to optimum coolant temps before i drive. i feel bad driving it stone cold
Old Dec 24, 2009 | 10:36 AM
Steve20's Avatar
Steve20
letting the engine 'warm up' to operating temps before driving not only wastes fuel, but causes increased wear in the piston ring to cylinder wall interface. When the engine is cold, it is dumping extra fuel into the motor, which has a tendency to wash the cylinder walls of oil, and increase the amount of unburned fuel in the oil, which causes the oil to loose some of it's viscosity index.
Let her warm up no more than 1 minute when cold and you will be doing the engine a favor. Just Cadillac it until oil temp gets to 150 or higher
Steve
Old Dec 24, 2009 | 10:39 PM
Choreo's Avatar
Choreo
Thanks for all the responses... sounds like I have been doing the right thing then!
Old Dec 25, 2009 | 12:13 AM
TEXHAWK0's Avatar
TEXHAWK0
I had a friend that would not drive the car until it idled long enough to get up to temperature, but modern cars are designed to be driven immediately at moderate speeds. Also, the engine will come up to temperature much quicker if you go ahead and drive it. Just take it easy for a few miles.
Old Dec 25, 2009 | 12:27 AM
dennyb7's Avatar
dennyb7
Back in the olden times you would warm up your car,not with the moden engines,just take it easy the first few minutes!
Old Dec 25, 2009 | 02:21 AM
thisMSGgood4me's Avatar
thisMSGgood4me
I try to keep the revs under 2K (at most 2.5K) until the the oil temp has reached mid-100s. By then the engine temp is getting close to normal (upper-100s). Won't drive it harder until tranny temp reaches at least mid-100s. I want to make sure the entire drivetrain is warmed up before getting on it.
Old Dec 25, 2009 | 08:08 AM
rebelheart's Avatar
rebelheart
While never a good idea to beat on a cold engine in any era,the modern syn oils will protect your engine very well without warm up.
Old Dec 25, 2009 | 08:13 AM
rws.1's Avatar
rws.1
just remember it can take 1-2 minutes for the cold oil to flow to all the critical wear surfaces... act accordingly
Old Dec 25, 2009 | 11:43 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
Steve
I don't know where you've gotten the impression that this is what takes place in a combustion chamber during open loop operation but it could not be further from the truth.
Raw fuel never enters the combustion chamber to wash away the oil film as you describe unless there is something drastically wrong with the injection system. Fuel is atomized by the injectors mixing with the incoming air to form a vapor, the vapor mixture is richer during the open loop cycle but not to the level you describe.
Any gasoline engine injesting enough raw fuel for what you described to happen would be belching black smoke like old coal burning steam powered locomotive.
The phenomena you described is caled "fuel dilution", and it does not happen in the manner you stated. It rarely occurs in fuel injected gasoline powers engines, especially ones that are operating correctly.
It is a good idea to allow the engine to warm a bit before driving and for it to reach normal operating temperature before exposing to high loads but not for the reasons this poster has stated.
Old Dec 26, 2009 | 03:56 PM
Bill Dearborn's Avatar
Bill Dearborn
That hasn't been true on engines since I started driving in the late 50s. The best rule of thumb to use when starting an engine in cold weather is to start the engine, fasten your seat belt, set the heater/defroster controls, check your mirrors and slowly drive away. If you drive a thousand feet the engine has gotten warmer in the time it took to drive that distance than if you sat and let it idle for the same time.
Bill
Old Dec 26, 2009 | 06:13 PM
Interspy24's Avatar
Interspy24
In the winter I let the car warm up for 3-5 minutes. I like the coolant temp to above 100 and the oil temp to be above 80 before I start driving. Then drive/keep the rpms under 2500 until everything is up to operating temperature.
In the summer, maybe 1 minute, then drive under 2500rpms or so until everything is up to operating temperature.
Old Dec 26, 2009 | 08:12 PM
Chevy-SS's Avatar
Chevy-SS
Steve
Yes, yes, I agree with everything here.
Except one thing - why do so many people insist on using the word "loose" when it should be "lose"? I see it everywhere.
LOSE - The oil will "lose" some viscosity if it gets diluted with fuel. You "lose" weight. You "lose" your keys. You "lose" the race. You "lose" a bet.
LOOSE - The bolt came "loose". My belt is "loose". The lug nuts came "loose" and my wheel fell off.
Old Dec 26, 2009 | 10:35 PM
Steve20's Avatar
Steve20
So you are saying there is no such thing as fuel diluting the oil on a cold engine?????
Have you ever had a used oil analysis performed on any of your vehicles?
Steve
To Warming Up Engine
