Balancer Pulley Change
Be sure and budget in a good tune. Your handheld days will be over if you put a nice cam in that car. Be mindful of the overlap in the cam if emissions are an issue. In Texas, they just plug into the OBDII port and make sure that it has the necessary "status ready" conditions. If that's the way they do it there, a good tuner can tune any cam and keep your PCM happy.
IF,,,,,,,,they run a sniffer test, a LARGE cam will most likely FLUNK because of the excessive hydrocarbons emissions.
We use to have a sniffer test here in CT. I put a NEW CAT in my 85 Coupe because the old CAT was plugged solid and the emissions stations operator ask me if my tail pipes were connected to my exhaust.
The new CAT was so efficient that the readings were far below the the allowable limits for a 150,000 mile C4 corvette. He broke out the mirror and inspected the entire exhaust system.
BC
I have the pulley,belts, and chain ready. I also have Manley 5/16X7.400 Chromoly pushrods $90 shipped. Let me know. Depending on cam size average 40-50 RWHP.John
I have a fairly agressive cam and comply with ALL of the CT Emissions (plug in) standards.
