Question on Lighter.
Old Dec 26, 2009 | 04:48 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Default Question on Lighter.
I use my dash lighter to power up my IPod and it is loose in the mount, Is there an easy to tighten up the back nut? I know I can take the console and Bezzel apart, Just thought maybe there was a better way.
Thanks.
Mr.Bill
Old Dec 26, 2009 | 05:02 PM
Pres712's Avatar
Pres712
Default Screw
Sure, just screw it. Seriously, without shocking yourself, it is inside a "barrel" and you should be able to just screw it tight. I just stuck my finger in and turned it. Be extra careful not to touch the bottom or you won't like the experience.
Old Dec 26, 2009 | 05:07 PM
Mr.Bill's Avatar
Mr.Bill
I thought of that, I was worried I would twist the power wire or something.
Thanks.
Bill
Old Dec 26, 2009 | 05:18 PM
Pres712's Avatar
Pres712
Thanks.
Bill
Don't worry, the power wire is a clip on and it will swivel. Plus the power wire is on the outside of the barrel. You will be turning the inside.
Old Dec 26, 2009 | 05:43 PM
Mr.Bill's Avatar
Mr.Bill
Worked like a champ.
Thank You....
Mr.Bill
Old Dec 26, 2009 | 05:58 PM
ALLEGRO's Avatar
ALLEGRO
Old Dec 26, 2009 | 06:03 PM
Mr.Bill's Avatar
Mr.Bill
Originally Posted by ALLEGRO
I thought of that happing....lol
Old Dec 26, 2009 | 08:07 PM
byronhunter's Avatar
byronhunter
That's not going to happen with 12 volts!
To Question on Lighter.
