fouling plugs need help
Old Jan 7, 2010 | 01:32 PM
dougbfresh's Avatar
dougbfresh
Originally Posted by eric04
well cleaned all the plugs and even relocated the computer, the wires were getting squeezed against the intake pipes of the turbos, problem still there, going to try to get a used pcm and see if that fixes it
Throwing a ECM at it is silly till you get it on a scanner do see what's going on (Injector duty cycle, watch the O2's working, etc). I would also check compression in that cylinder vs. one that's not fouling. One cylinder fouling after you've swapped plugs/wires/injectors probably means valvetrain or compression issues.
Old Jan 7, 2010 | 02:49 PM
eric04's Avatar
eric04
i had it on the scanner no codes, o2 is fine, and what makes me think its something to do with the pcm sending a signal to the injector is because if we clean the plug, the car runs like a beast from 700rmp to 6800 no missing or anything, for a while then just starts missing again out of nowhere. and its always the same cylinder, we moved the coil, the plug, the wire, and the injector to a different cylinder and the problem stayed in #1
Old Jan 7, 2010 | 04:09 PM
dougbfresh's Avatar
dougbfresh
Scanner I was referring to allows you to graph sensor input/output and computer in/out to see what the computer sees. Normal OBD readers and the DIC will not give you all this info. It's something not under computer control causing your problem. Do you ever get P0301 codes when the miss finally happens?
Low compression would explain this, not allowing all the fuel to burn till it fouls the plug. If it's gas fouling there is either too much fuel entering or NOT being burned. I assume it's fuel fouled not oil.
Old Jan 7, 2010 | 11:29 PM
HorsePowerAddicts's Avatar
0HorsePowerAddicts
Former Vendor
Try a compression and a leakdown test to verify if it is a mechanical problem.
Old Jan 8, 2010 | 09:52 AM
eric04's Avatar
eric04
checked the compression, its the same as the other cylinders, no loss of compression in the #1 cylinder,
Old Jan 8, 2010 | 10:01 AM
dougbfresh's Avatar
dougbfresh
Did you try a new plug in that cylinder, not just clean the old one?
Old Jan 8, 2010 | 10:27 AM
eric04's Avatar
eric04
yes we put a brand new one in there
Old Jan 8, 2010 | 10:55 AM
dougbfresh's Avatar
dougbfresh
See if it runs OK after a cold start then starts missing once it's warmed up.
Old Jan 8, 2010 | 11:18 AM
eric04's Avatar
eric04
ok,
Old Jan 8, 2010 | 11:26 AM
eric04's Avatar
eric04
just went for a ride, after a few blocks it starts to miss, also it only does it under load, not if i just bring the rpms up in the shop, the problem occurs at lower rpm between 2-4k and part throttle, no problems at full throttle
Old Jan 8, 2010 | 11:42 AM
dougbfresh's Avatar
dougbfresh
But no P030X codes right?
Old Jan 8, 2010 | 11:50 AM
eric04's Avatar
eric04
no there are no codes at all since i cleared them
Old Jan 8, 2010 | 01:22 PM
  #33
dougbfresh's Avatar
dougbfresh
Bet you have some type of valvetrain issue on that cylinder. Can you get the valvecover off to look at the spings?
Old Jan 8, 2010 | 01:30 PM
  #34
eric04's Avatar
eric04
if it was a drivetrain issue wouldnt it be there all the time, like i said when we clean the plug or put the new one in, the car runs perfect all the way up to 6800rpm no miss, nothing if i had a broken spring or something would it run that good with a clean or new plug?
Old Jan 8, 2010 | 01:45 PM
  #35
dougbfresh's Avatar
dougbfresh
If a valve is not working right it could cause the problem. You issue is not with the computer. Whatever it is is not computer controlled or monitored. Sinice your not getting any P030x codes, the computer does not believe you have a miss. If you had a better scanner you can see the misfires per cylinder.
Old Jan 8, 2010 | 02:20 PM
  #36
eric04's Avatar
eric04
as far as i know we are using a better scaner its a snap on scaner its my mechanic friends and when we hook it up and go for a ride it shows how many misfires are in the #1 cylinder, in each cycle, when it happens we get 100-200 misfires in that cycle, and in a 5 min ride we may get 1100 or so misfires in the #1 cylinder,
also went for another ride and when misfire happens the engin light flashes my friend said that means its reading a misfire, but still no pcm codes in history, i dont understand it, we are just thinking that maybe since there are injector modules in the computer maybe one is not working right, and it is sending the wrong signal to the injector, it doesnt know its not working right so no code
Old Jan 8, 2010 | 03:17 PM
  #37
dougbfresh's Avatar
dougbfresh
The scanner should also whow the injector pulse. You could also put a noid light on it to make sure it's getting a pulse. If your getting the flashing CEL then you should at least see a P0300 or P0301 H code.
Did you swap coils on that cylinder too?
To fouling plugs need help
Old Jan 8, 2010 | 03:26 PM
  #38
eric04's Avatar
eric04
i just went out and checked the DIC codes again, and no codes at all, yes we changed the coil, the plug wire, the plug and injector to a different cylinder but the problem stayed in cylinder #1
Old Jan 14, 2010 | 03:37 PM
  #39
eric04's Avatar
eric04
Old Jan 14, 2010 | 03:50 PM
  #40
dougbfresh's Avatar
dougbfresh
Pull the valve cover and check the spings and pushrods on that cylinder.
