fouling plugs need help
Yes there are sensors that if they get wet, they wont work but,,,the list is LONG.
Post your DCTs. If there are tons of them, CLEAR them all and take the car for a drive and see hat comes back and then post those DTCs
If you don't know how to read and post your own codes, heres the write up you need:
READING YOUR Engine Diagnostic Codes (DTCs)
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open etc…)
3) Press and hold OPTIONS
4) While holding OPTIONS, press FUEL four times within a 10-second period.
Initially, on-board diagnostics go into an Automatic Mode which shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each. ( i.e. PCM = 4 codes)
If none are present in a given module, you will see No More Codes on the display.
There are two kinds of diagnostic codes, Current and History designated with a letter suffix, C or ;H. A current code indicates a malfunction is present in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes.
More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except E/M. Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present;
press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press RESET
To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5.
Here is very good site of DTC definitions:
http://www.gearchatter.com
Make sure to include the H or C suffix!!
PCM, - P0171C
TCS, - C1287H, C1288H,
SDM, - U1016H
AU LDCM, - B2282H, B2286H, B2284H, U1255H, U1064H, U1016H, U1096 H
A1 RDCM, - B2283H, B2287H, B2285H, U1255H, U1064H, U1016H, U1096 H
BO RFA, - U1096H, U1016H
IT SEEMS SOME OF THEM REPETE THEMSELF IN THE DIFFERENT MODULES I DONT KNOW WHAT THAT MEANS. ANY HELP WILL BE GREAT THANK YOU.
pcm, - p0171c
tcs, - c1287h, c1288h,
sdm, - u1016h
au ldcm, - b2282h, b2286h, b2284h, u1255h, u1064h, u1016h, u1096 h
a1 rdcm, - b2283h, b2287h, b2285h, u1255h, u1064h, u1016h, u1096 h
bo rfa, - u1096h, u1016h
it seems some of them repete themself in the different modules i dont know what that means. Any help will be great thank you.
DTC P0171 or P0174
Circuit Description
The powertrain control module (PCM) controls the air/fuel metering system in order to provide the best possible combination of driveability, fuel economy, and emission control. Fuel delivery is controlled differently during open and closed loop. During open loop, the PCM determines fuel delivery based on sensor signals without oxygen sensor input. During closed loop, the oxygen sensor inputs are added and used by the PCM to calculate short and long term fuel trim fuel delivery adjustments. If the oxygen sensors indicate a lean condition, fuel trim values will be above 0 percent. If the oxygen sensors indicate a rich condition, fuel trim values will be below 0 percent. Short term fuel trim values change rapidly in response to the heated oxygen sensor (HO2S) voltage signals. Long term fuel trim makes coarse adjustments in order to maintain an air/fuel ratio of 14.7:1. If the PCM detects an excessively lean condition, this DTC will set.
The U series DTCs indicate a loss of communications. I agree. Clear all and see what comes back. Make sure that your battery is fully charged before you restart it. A low battery will set DTCs when you crank the engine.
BC
Just a thought
Pat Kunz
its only the #1 plug fouling, and tried changing everything, plug, coil, wire, injector, still #1 plug fouling, found out the pcm controlls each injector seperatly, and which wire is for that injector, going to take down the pcm and clean all the connectors if that doesnt fix it i think we may try a different pcm.
