Cam Position Sensor?
Old Dec 28, 2009 | 09:00 PM
Silverbullet6spd's Avatar
Silverbullet6spd
Default Cam Position Sensor?
I'm throwing codes for cam sensor-low voltage. I've searched but cannot find an exact location. I've searched and read somewhere at back of intake? I pulled the A.I.R tube out yesterday and wondering if I damaged it. it's a 2004 LS6. Cam bolts have been loc-tite'd
Old Dec 28, 2009 | 09:03 PM
lucky131969's Avatar
lucky131969
Yep, it's under the back of the intake next to the oill pressure sensor. You might have damaged it, or the wire bundle.
Old Dec 28, 2009 | 09:16 PM
Silverbullet6spd
I can feel a sensor that feels like it might be broken, not sure if that's it or not. Anybody got a pic?
Old Dec 28, 2009 | 09:29 PM
AllVette's Avatar
AllVette
Old Dec 28, 2009 | 09:33 PM
Silverbullet6spd
Thanks, that's a big help. Does the intake have to be removed to swap out?
Old Dec 28, 2009 | 09:36 PM
lucky131969
Yep.
Old Dec 28, 2009 | 09:39 PM
Silverbullet6spd
Marvelous. Thanks for the help.
Old Dec 28, 2009 | 09:59 PM
Silverbullet6spd
Guys, thanks for the help. I unplugged the connector and found a broken wire. Gonna fix it tomorrow and get it going. Could'nt have figured it out without you. All these because I just HAD to remove the air pump.
Old Mar 30, 2010 | 02:30 PM
3someC5's Avatar
3someC5
im getting the high voltage code... and suggestions?
Old Mar 30, 2010 | 02:33 PM
Sinking's Avatar
Sinking
Check for a short to voltage.
Old Nov 15, 2010 | 12:18 PM
C5Joe559's Avatar
C5Joe559
I'm throwing the same code after my mechanic replaced mine. Could it just be a faulty sensor? My car sometimes won't turn on, and I'm guessing a bad wire. Also while he has the intake manifold off...again, does anyone have a picture of where the oil pressure sensor is in comparison to the cam position sensor? Thanks!
Old Nov 15, 2010 | 12:42 PM
LoneStarFRC's Avatar
LoneStarFRC
Post #4. Little brass jobbie just to the right of the cam sensor.
Old Sep 15, 2011 | 04:56 AM
amccomb's Avatar
amccomb
Whats the differents between the low and high voltage cam position sensor code? About how long do you think it would take to get the intake off to get to the sensor?
Old Oct 26, 2011 | 10:27 PM
Wkeil99hardtopred's Avatar
Wkeil99hardtopred
Im having an issue where my cars cranking and not firing. well if i have the intake off might as well put an ls6 on it
Old Oct 27, 2011 | 10:04 AM
johnnyzvette's Avatar
johnnyzvette
I just installed an LS6 intake on my 98 and i can definitely feel a difference over the LS1 style!
Old Oct 29, 2011 | 01:40 AM
1973convertiblevette's Avatar
This issue should be a crank shaft postion sensor, rather than a cam shaft postion sensor. Its a very common issue, as I sell them to people at work with this problem all the time, and it usually fixes the problem. That is if you are still getting plenty of fuel pressure, air, and spark. I'm not positive of the location on the LS1.
Hope this helps -David
To Cam Position Sensor?
