Best gasket to use
Dec 29, 2009 | 06:16 PM
Best gasket to use
I am ready to install LG headers on my 2003. What are the best header gaskets to use? GM OEM or is there somethig better?
Dec 29, 2009 | 06:52 PM
St. Jude Donor '08-'09-'10
I just installed my headers last week (LGM as well, on a 2003 Z) and I used the F-body gaskets, GM part no. 12558573. I've read in numerous places that they are better than the stock gaskets because the exhaust ports are fully round rather than oval-shaped. I'm guessing it helps the exhaust flow better. If I recall, I think that was even the recommendation from LGM when I ordered my headers.
I bought them for $10 each from Fichtner Chevrolet (forum vendor). Be careful though, you'd think something like gaskets come priced per pair but these don't! I almost ended up with only one gasket.
btw... in case you don't have a good set of instructions for the header install... I found these very useful.
http://www.cajundude.com/longtubes.htm
edit: Here's a pic of the F-body gaskets vs. the stockers (from Cajundude's instructions above)
Dec 29, 2009 | 08:02 PM
Alaskanpilot hit the nail on the head.
Dec 29, 2009 | 10:27 PM
I used GM p/n 12553617 which are also metal gaskets with round ports and look identical to ones pictured above...not sure what the difference is?
Jan 10, 2010 | 12:37 PM
Jan 10, 2010 | 04:46 PM
As said above just pick up a set of gm ls1 fbody gaskets. Those are better than the aftermarket gaskets.
Jan 10, 2010 | 06:10 PM
Quote:
Originally Posted by
HorsePowerAddicts
Feb 22, 2010 | 11:32 PM
St. Jude Donor '06-'07-'08-'09
is GM P/N 12558573 the correct number for these gaskets?
looks like the new number is 12617944
where's the best place to purchase these?
Feb 23, 2010 | 07:30 AM
When I installed my ARH, i used the gaskets they sent as part of the kit.
They looked just like the Fbody pictured.
Feb 23, 2010 | 10:39 AM
That was my choice also,,
Oct 15, 2010 | 01:33 PM
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Ive used several different aftermarket gaskets and my next header gaskets are the GM LS1 gaskets.
BC
Oct 15, 2010 | 01:42 PM
I've used those same f-body gaskets on my Camaro and my Vette, they are flawless.
Dope
