East Coast Supercharging Quality???????
BTW, dig the old skool EVH avatar.
Whadya think ???????
Now I know you are a Vette man that knows his nuts! and bolts.
with a "nuts"
possibility on the side.
The torque tamer appears to be the item that reduces torque tube bending and whip. Not sure if it solidly mounts to the tube or provides a displacement limit. All the photo's are without the torque tube in place.
Everything flexes to a certain designed degree.My thoughts on the differential brace is that is keeps pressure on the transmission / differential joints to prevent excessive flexing at these points since they are the weakest link due to the long mainshaft used in our vettes. Most other vehicles have extension housings that support the mainshaft whereas the vettes (C5 / C6) do not have this support design.
I would have asked ECS directly/discretely. If I had chosen to post about it not knowing whether the practice was acceptible or not, I would have just presented the question and left the vendor name out of it.
We can split hairs all day and disect and play semantics... bottom line as I said before people need to lighten up. I am sure ECS did not loose 100 customers because of this thread
They have a very solid reputation on this board.People need to relax
Lets move on.
Lets move on.
, hence post #52.
What my install looks like.
The factory A/C tensioner retainer location they use for the lower mount for the ECS tensioner. This bolt from the factory has a Teflon/plastic washer installed on the shoulder of the bolt to hold the front of the tensioner to a specific tolerence (I suspect because I didn’t engineer it). With this factory bolt in place there is .045 of front to back movement at the outer edge of the pulley. With the ECS spacer installed there is a complete .10 of movement at the outer edge of the pulley. This was also designed by ECS to ease installation across different years of C5’s and aftermarket A/C tensioners. I thought .10 of movement was excessive and took care of it.
The factory bolt and washer.
ECS spacer installed as purchased
As I installed it
The last piece I installed was the oil line block. Doug didn’t comment on this one. Every machined side of this block except the one where the gasket goes was nice. I filed smooth the gasket surface to stop any possible oil leaks from the roughness. I also had to cut down these bolts 3/8 of an inch because that is how far they stuck out when bottomed in the block. No I didn’t file off 3/8 of an inch to smooth out through surface so that’s not the reason for the bolts to be too long.
Block surface
Long bolt
Cut bolts
The brace, well we have worn that issue out. There are those that will install the same as factory hardware and those that won’t. Yes, it’s that simple.
I install the tensioner and the oil block over Xmas so calling ECS wasn’t going to happen. This allowed me to continue with my build and keep it on my schedule. I figured I would get the standard “we have sold 1000’s of these and never had a problem” answer anyway so why add to my aggravation. The answer Doug gave me was very close to this but with some explanation.
Again this wasn’t a post to demean ECS and if you think it was I believe that’s an immature view. It was just constructive criticism and did bring out some good discussion on hardware awareness.
ECS or I do not condone any of these "mods/changes" so if you do them do them at you own risk.
The higher grade bolts will cost more than the lower grade bolts when Joe the Vette owner buys them from wherever.com. This is obvious to all. What might not be so obvious is that in assembly type manufacturing, that "higher cost" bolt can actually become a lower cost bolt IF it is used in multiple applications. Reducing inventory in assembly production is one of the most commonly used ways to save costs in recent times. Reducing inventory has a cost saving ripple effect.
Stock floor space is recovered (which can be used for more mfg), tax is saved on reduced inventory, less material planning is needed, ect.
So if this "higher grade bolt" can replace a number of other bolts (with different part numbers) there can be a decent overall cost saving to the manufacturer.
