Engine Oil Temp Too High?
Old Jan 2, 2010 | 07:58 PM
C5Natie's Avatar
C5Natie
Default Engine Oil Temp Too High?
Hey guys, after some hardcore high rpm canyon carving yesterday and today after soem spirited driving I took a look at my oil temps. Yesterday was 244 and today was 255 degrees. Does that sound too hot? The motor is newly forged (2500mi) rebuilt LS6 with 12:1 compression and I just started using Royal Purple 15w-40 now that broken in. Is it time for an oil cooler?
Old Jan 2, 2010 | 08:12 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
That's not TOO hot, but if you see 250+ oil temps more often than not, an oil cooler would be a good idea.
Old Jan 2, 2010 | 08:19 PM
RaleighSS's Avatar
RaleighSS
I do not think 255 is bad at all ..... Consistent 280s / 290s may be time to get concerned. Normal day to day driving puts you probably near 200 / 210 right? If you track the car I think a oil cooler would be needed as you will see temps right up near 290/300 with a LS6. Canyon Carving is probably not something you do every day so I would think the occasional 250 / 260 will not do any damage at all. Lets see what others think...
With oil cooler on my LS6 pushing hard she runs near 260 .... Normal driving puts it at about 180 uncovered and covered near 190/195 (have to cover it with cardboard during NC winter to get temps up)
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
No issue with 250 temps. Have fun...
Old Jan 2, 2010 | 08:20 PM
C5Natie's Avatar
C5Natie
This was some pretty hard driving so Im sure that reg driving temps should be fine. Also I wannabe safe come summer time. Thats why I went with Royal Purple, I wanted a good synthetic that will hold up in high heat apps too.
Old Jan 2, 2010 | 08:23 PM
C5Natie's Avatar
C5Natie
Thnx guys. I will keep my eye on regular driving temps too. One more thing, its been around 40 degrees where I live in the mornings and 45-50 at night. I wonder if it will take forever to get the oil up to temp with a cooler?
Old Jan 5, 2010 | 07:47 AM
RaleighSS's Avatar
RaleighSS
With a Oil Cooler you will notice lower temps and longer warm up times but soon as fall arrives I put a piece of cardboard in front of mine and it gets my temps up about 15 ....
Old Jan 5, 2010 | 01:56 PM
Chicago1's Avatar
Chicago1
That's about the temp I run when I'm racing temps ar enear about 225-232 for coolant and 250-260 for oil which is normal operating range.
Old Jan 5, 2010 | 02:35 PM
AU N EGL's Avatar
AU N EGL
I just block my oil cooler off with a zip tied piece of plastic in cold weather
Old Jan 6, 2010 | 02:27 AM
C5Natie's Avatar
C5Natie
Today was a warmer day and I noticed oil was around 200-205 degrees. After a few minutes of driving in 3rd on the freeway just to see what it did it got up to 260 but quickly went down after regular cruising. Im thinking a cooler might be a good idea as the weather gets warmer plus I always let the car idle for a while as it gets warm before driving. Any cooler recommendations? Ive seen a nice B&M kit for $120, stack plate style cooler.
Old Jan 6, 2010 | 01:20 PM
Steve20's Avatar
Steve20
get one with a thermostat
Old Jan 6, 2010 | 06:09 PM
VGLNTE1's Avatar
VGLNTE1
St. Jude Donor '14-'15
its fine. mine runs at 225 at normal highway driving. 260-270 if i beat it.
Old Jan 6, 2010 | 06:17 PM
GeorgeZNJ's Avatar
GeorgeZNJ
St. Jude Donor '08-'09
I didn't really worry aout temps on the street, and I drive pretty hard. On the track I started hitting 300-305, so I had ECS install a DeWitts combo, have never had a problem since.
Old Jan 6, 2010 | 07:57 PM
John Dingman's Avatar
John Dingman
I would have to agree with these guys. These temps don't seem that bad compaired to some that I've heard about. But if you're still concerned about and you want to improve your coolant temps as well, we offer a combo unit like the one stated above. It's our A97EL radiator EOC combo. It has twice as thick radiator as your stock unit with an intergrated EOC in the driver side tank. Here is a link to our web page which also talks about the hose kit to install it with.
http://www.dewitts.com/pages/product...asp?ProdID=350
Thanks,
John
Old Jan 6, 2010 | 08:03 PM
VGLNTE1's Avatar
VGLNTE1
oil coolers intigrated into the rad always freaks me out. I think if it ever leaked, id have a nervous breakdown
Old Jan 7, 2010 | 09:34 AM
C5Natie's Avatar
C5Natie
Thnx guys. I know temps could be worse but I just wanna make this powertrain last as long as possible especially since this motor is a revver and already creates a lot of heat. Those radiators seem pretty cool too, def a possibility.
As for an oil cooler, do any of you if this B&M kit will work on a C5? Ive seen it on LS1 Camaros but I just wanna make sure the oil filter adapter works on our oil pans. Thnx.
http://www.jegs.com/i/B-M/130/70270/...oductId=751470
Old Jan 7, 2010 | 09:36 AM
C5Natie's Avatar
C5Natie
Lol. It is scary if that happened but im sure those radiators are nicely welded.
Thing is I still want a few more mods before I drop $500+ on a radiator.... even though it is worth the money.
To Engine Oil Temp Too High?
Old Jan 7, 2010 | 12:56 PM
MattB's Avatar
MattB
Just putting in a DeWitts rad with out connecting the oil cooler will still lower the oil temps. IMO, I wouldn't suggest putting in a dedicated oil cooler before putting in an upgraded radiator.
I'd be more afraid of not getting the lines secure or melting a hose because its too close to the exhaust, or routing it badly and causing it to rupture or leak (oil burns well). A lot of things to go wrong for no real gain. DeWitts has a nice setup to connect the oil cooler to the engine, has hard lines near the engine which makes a lot of sense to me.
Lastly, the kit you show above looks to have a connector that goes between the oil filter and the engine, this will put your oil filter very close the the ground and may not be a good idea. DeWitts and Lingenfelter replace the oil temp sensor with a unit that routes the oil to the cooler and supports the temp sensor, a much better design for the Vette.
Old Jan 7, 2010 | 01:02 PM
lucky131969's Avatar
lucky131969
Yeah, next thing you know, someone will get the crazy notion to cool the transmission fluid through the radiator....
Old Jan 7, 2010 | 02:05 PM
waddisme's Avatar
waddisme
That is about the size of the oil cooler I have on my very hot 402. I don't think you want to do the sandwich adapter as it will lower the oil filter too low. It is best to run an adapter off of the the oil pressure sensor right above the oil filter. Do a search in the road racing section and you will find numerous threads and how tos. If you are doing it right, might as well do the steel braided -an lines also.
