Roller Rockers - Need Some Info
Old Mar 5, 2002 | 10:36 PM
Cam69ss's Avatar
Cam69ss
Default Re: Roller Rockers - Need Some Info (jeff_nation)
The hotrocker is a neat product. Has anyone used it? it might be good to test out on an old small block.
Old Mar 6, 2002 | 08:26 AM
Mike@NorrisMotorsports's Avatar
0Mike@NorrisMotorsports
Former Vendor
St. Jude Donor '11
Default Re: Roller Rockers - Need Some Info (Mean Green 2000)
I guess I'll put my two cents in here. I do not like the idea of the 1.8's as, like Chris mentioned and others, for the money of these and install you could get a custom ground cam and springs installed for abot $200 more and have what you need.
The stock rockers do vary from 1.7, but in favor of more lift. they are generally 1.73-1.75 and have seen 1.77, so the 1.8's are not a big of a lift increase as one might expect. Therefore not as much HP gain as the older small blocks and LT1's when you went from the 1.5's to 1.6's. Now that works great. Roller tips would be nice to have, but the stockers seem okay at this point.
I have used the Jesel non adjustables with a custom ground cam and prefer that method. The adjustable Jesels are nice, but need different covers or spacers. Now if Crane would offer their kit in a 1.7 ratio and keep the rest of the parts the same to be adjustable, then that would be great and sell like crazy I believe. Perfect for heads/cam cars with milled heads to set geometry.
I have seen the Hot Rockers, and they may be fine for a lower spring pressure and lower RPM application, but high seat and open pressures that we use these days to get 425+WHP I would think reliabiltywould be a long term issue. Plus the stockers, once again, seem to do very well considering.
Later,
Mike :cheers:
