Magnesium wheel question
Old Jan 6, 2010 | 12:09 AM
dennyb7's Avatar
dennyb7
Default Magnesium wheel question
Do you have to have the rubber rings that go behind Corvette Magnesium wheels?
Old Jan 7, 2010 | 11:18 AM
dennyb7's Avatar
dennyb7
Ttt
Old Jan 7, 2010 | 02:27 PM
Evilash's Avatar
Evilash
There are rubber rings? Like a spindle to wheel gasket or something?
Old Jan 7, 2010 | 05:43 PM
dennyb7's Avatar
dennyb7
Its a rubber gasket that was attached to the back ,and by attached I mean they were just stuck on to two of my rims when I purchased.They go on back of rim between disc and back of rim.
Maybe they are used because its two different metals!
Old Jan 8, 2010 | 10:40 AM
87SAM's Avatar
87SAM
Yep, that's the reason. Many people with mag wheels seem to be missing 1 or 2 of them.
Old Jan 8, 2010 | 11:51 AM
c5vetteguy's Avatar
c5vetteguy
2018 C5 of Year Finalist
I contacted Speedline about these as I'm missing a couple myself. They are no longer available from the manufacturer.
The reason for these is not the difference in metals, but they are simply a watertight gasket to keep moisture from the inner hub area of the wheel. Uncoated magnesium's exposure to water will corrode the wheel over time. I drove mine all summer without these rings with no issues whatsoever. I am in the process of having my wheels powdercoated, so this hub area will be taken care of.
You may want to throw some paint or coating on the inside hub area to minimize any corrosion potential.
Old Jan 8, 2010 | 04:48 PM
Evilash's Avatar
Evilash
huh. I'm missing all four. I will have to get in there and paint I guess.
Wish I'd known this when I had the wheels off for the Z06 vent install.
Old Jan 8, 2010 | 09:43 PM
dennyb7's Avatar
dennyb7
I had my wheels refurbished after I bouht them at Carlisle and they were repainted the bronz tone so I guess I'm alright.But maybe I'll take them off and add and extra coating Thanks guys
Old Jan 8, 2010 | 09:59 PM
c5vetteguy's Avatar
c5vetteguy
I wouldn't get paranoid over this. I tend to address issues before they become such, but that's just me. If you don't drive or live in a high-humidity/rain area or you wash your Vette often, the magnesium corrosion issue shouldn't be a problem. If you do and don't have the rings, it may be worth inspecting your wheels. It should be a one-time look-see, address-and-forget.
To Magnesium wheel question
