service column lock
Old Mar 4, 2002 | 04:28 PM
roddog's Avatar
roddog
Default service column lock
wth does this mean, i hit reset and it goes away, its this something urgent or another reason to go in and spend 200 bucks
Old Mar 4, 2002 | 04:42 PM
blackvette1's Avatar
blackvette1
Default Re: service column lock (roddog)
The column lock is stuck in the open position. You can drive around with it fine but I'm not sure for how long. I had to take mine to the dealer to get it fixed.
Old Mar 4, 2002 | 04:45 PM
HummelS's Avatar
HummelS
I had the same problem with mine. It means your column lock isn't functioning correctly - probably stuck in the "open" position, since you can still drive the car. Usually a symptom of a Body Control Module (BCM) computer problem, it can sometimes be corrected by pulling fuse 25 in the passenger footwell, wait 15 secs, & reinsert fuse.
You should have your dealer check to see if your car qualifies for the recall on column-lock problems: it can also stick "closed," when you start the car, in which case you are stuck with a locked steering wheel.
Old Mar 4, 2002 | 04:51 PM
roddog's Avatar
roddog
Default Re: service column lock (thevettenet CA)
ill give that a try, thanks, i know that the car has already been in for this recall b/f i bought it, i wonder if this will still apply even if the warranty is out, as of last month that is :boxing
Old Mar 4, 2002 | 05:13 PM
HummelS's Avatar
HummelS
Recall should apply even after warranty is out, but I would guess it's just a BCM reset that'll fix it. Let me know how it works out.
btw, also check to make sure your a/c condensation is draining properly - if the drain hole gets plugged up, condensation can overflow and drown the BCM - found this out the hard way, too! :mad
Old Mar 4, 2002 | 05:16 PM
roddog's Avatar
roddog
geez, dont tell me that, but i know i havent had the ac on in months:D, ill let you know if it works tonight, cause if not its going to the dealer in the morning
To service column lock
