Trunk won't open
Old Mar 4, 2002 | 04:56 PM
Madd Skillz's Avatar
Madd Skillz
Default Trunk won't open
First post on corvetteforum!
I've been experiencing a problem where I can't open the trunk when the car is running and in neutral. It can't be open from either the automatic trunk latch on the dash, or the keyless remote. It seems to be an intermittent problem, but once I turn the car off, the trunk can then be opened. Any ideas???
[Modified by Madd Skillz, 8:57 PM 3/4/2002]
Old Mar 4, 2002 | 05:04 PM
roddog's Avatar
roddog
Default Re: Trunk won't open (Madd Skillz)
i dont think i can open mine while the car is running
Old Mar 4, 2002 | 05:06 PM
C54TIM's Avatar
C54TIM
The vehicle has to be in Part for an automatic, and in neutral with the parking brake set for a stick! Try setting your parking brake and having the transmission in park.
Old Mar 4, 2002 | 06:52 PM
barryscott's Avatar
barryscott
Hey Now:
First, welcome to the forum. :cheers: On my 2001 A4, just have trans in park, hatch will open with engine running. :yesnod:
Old Mar 4, 2002 | 07:11 PM
Sales@MVPAutoParts.com's Avatar
0Sales@MVPAutoParts.com
Former Vendor
The button on the dash in my car would not open the hatch at all, regardless if it's in park or with the engine off. I have to use the keyless remote each each time.
I was messing with the traction control switch few weeks ago, so that might have something to do with it. I've looked at the both fuse boxes and all the fuses seem to be OK.
Any suggestion? :confused: :sad:
-Tuan
Old Mar 4, 2002 | 07:16 PM
C54TIM's Avatar
C54TIM
Default Re: Trunk won't open (Tuan Le)
Try pulling the fuses, forgot which ones, check the manual. And pull the switch out of the dash and check the connection.
Mine did that once, I pulled the fuses and put them back in and it worked.
The C5 is a strange beast. With mulitplex cabling and floating grounds, anything can happen.
Tim
Old Mar 4, 2002 | 07:21 PM
Former Vendor
Default Re: Trunk won't open (C54TIM)
Tim
Are you referring to the regular manual or the repair manual?
-Tuan
Old Mar 4, 2002 | 07:28 PM
C5Noir's Avatar
C5Noir
Ditto that!
To Trunk won't open
