Power Window sometimes doesn't work
Old Jan 7, 2010 | 09:04 PM
SNOTRKT's Avatar
SNOTRKT
Default Power Window sometimes doesn't work
My C5 most of the time the switch works and the drivers window goes up and down but the odd time it stops. When you open the door though it works fine again and never has this issue when the door is open. I bought a new door switch cluster and still have the same problem. Is there something in the door that will cause this ?? a relay maybe ? motor pooched ?? I wouldn't think it's the motor since the window does work fine when it works.
Any idea's. I'm thinking posible relay and GM says thats $600.
