header install ????
Old Jan 9, 2010 | 11:28 PM
2slow4you's Avatar
2slow4you
Default header install ????
im about to install some headers on my C5, had a few ???'s.
for my front o2s, how long of a extension will i need? my x pipe looks like it takes a gasket for my catback? does it?
Old Jan 10, 2010 | 12:01 AM
HorsePowerAddicts's Avatar
0HorsePowerAddicts
Former Vendor
What headers are you going with? Most include the correct O2 extensions. Yes there are gaskets that go between the x pipe and the catback.
Old Jan 10, 2010 | 12:10 AM
2slow4you's Avatar
2slow4you
i have some lg motorsports, bought them used from a member on here. guess i could call them and ask.
were can i get these gaskets at?
Old Jan 10, 2010 | 12:20 AM
0HorsePowerAddicts
Former Vendor
I normally just get the rear exaust gaskets from Kooks with the exhaust. The dealer will also have them.
Old Jan 10, 2010 | 09:21 AM
vettenuts's Avatar
vettenuts
Are they LG Pro's? You need a connection for the rear O2 sensors so they can be installed in the front. This will actually give you a lot of extra so you will need to coil and tie them off so they don't contact the exhaust. The gaskets for the cat back connection can be bought from GM. Either a dealer or one of the forum vendors. I have a set I am going to install in the spring and am gathering the necessary pieces as well. I am going to install plugs in the rear O2 sensor locations as the rear O2's are currently tuned out in my current header setup.
Old Jan 11, 2010 | 03:31 PM
Rossi396's Avatar
Rossi396
2Slow:
I used the existing O2 harnesses on my install and they worked fine. I just pulled the harness / attachment clips that held the harness in place away from the tunnel area and made sure the harness wasn't contacting anything. I also left my rear O2's in and never had an issue. (I did eventually have ECS tune them out, but I drove the car for three months with no codes)...
Regards,
Rossi
Old Jan 11, 2010 | 03:37 PM
01_torch_red_vette's Avatar
01_torch_red_vette
same here, i have arh long tubes and i didnt have to use any extensions. just removed some of the clips for extra slack
Old Jan 11, 2010 | 03:49 PM
The Wrench's Avatar
The Wrench
We recently installed LG streets with hi-flow cats on an '04.
The stock rear sensor wires were just long enough to route and connect to the original harness with no extensions. The fronts required extensions, which are about a foot long - four of these came with the headers, we used two. We left all the sensors in their original location, and hooked them up, but later had the rears turned off when we had the car tuned.
DG
Old Jan 11, 2010 | 04:05 PM
aweil's Avatar
aweil
I recently installed a set of LG Pros on my 2002 Z06. The instructions that come with the headers tell you to install the headers from the bottom, but I installed mine from the top. The passenger side went in very easily, no issues. For the driver side I had to remove the alternator, valve cover, unbolt the steering shaft, pull the power brake booster line and yank the oil filter... it then took a bit of wiggling to get it in which would be much easier if you had a helper below the car to give you a hand.
To header install ????
