LS Thermostats.. lower temp tip......
Old Jan 10, 2010 | 11:28 PM
tommie's Avatar
tommie
Default LS Thermostats.. lower temp tip......
http://www.texasperformanceevents.co...7501#post37501
Just passing this on for others to save a little $$$$
On the LS engines there seem to be 2 different thermostat designs an early one where the thermostat is made into the thermostat housing 97-late 03/early 04...
And the 2nd design where the thermostat is separate from the housing 03-04/ to current....
Lower temp thermostats are available from different performance vendors...usually the early style is about $60-65, and the later style is sold for about $25-30....
What I wanted to pass along was a cheaper way to buy a lower temp LS thermostat......
OReilly auto parts....
early thermostats........(housing and thermostat 1 piece)
160 DEG part # 37960 $29.99
180 DEG part#37980
187 DEG part# 37987
later type......separate thermostat
160 DEG part# 6367 $18.53
180 DEG part# 6368 $18.53
195 DEG part# 6369 $18.53
Old Jan 11, 2010 | 10:41 AM
aweil's Avatar
aweil
You can modify your OEM thermostat to open at whatever temperature you want for the price of an 1/8" brass ferrule, a file, a caliper, and your time.
http://teamzr1.com/modstat.html
I made a .075" shim for my car and it seems to want to run 180 degrees or so now.
Old Jan 11, 2010 | 11:31 AM
DFOR's Avatar
DFOR
tommie,
Thanks for that info. If I wanted to switch to a 160 degree thermostat, I assume I'd get the 6367??? I have a 2004 convertible.
Old Jan 11, 2010 | 11:34 AM
aweil's Avatar
aweil
Originally Posted by DFOR
tommie,
Did you miss the part where I posted up how to mod your stock stat to do what you are wanting for a DOLLAR? lol
Old Jan 11, 2010 | 03:20 PM
tommie's Avatar
tommie
tommie,
that should be right for an 04'... you will see when you take it apart...if the thermostat is made into the outlet, it is an early type...if the thermostat is separate then it is a later type..
yes, I saw that too... my only problem, is that from experience I have seen thermostats fail over time, they wear from constantly opening and closing, and eventually fail. I have a better piece of mind in replacing my thermostat with a new one.
I would feel confident with your mod if I was using a new stock temp thermostat, but I would not want to mod a used thermostat.
Old Jan 11, 2010 | 03:44 PM
aweil's Avatar
aweil
Understood. My 83k modded stock thermostat is working fine, but it is a PITA to drain the coolant to swap it out again.
Old Jan 12, 2010 | 12:06 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
No need to drain the coolant. You pull the hose and hold it up quickly to minimize leakage. Loosen the bolts while holding the housing in place. Have the new one right there handy. Then remove and reinstall as fast as you can. Install the bolts and hose and you're done. I lost only ounces of coolant. One of the easiest and quickest mods I've done. Just have to be fast and have that new housing ready to slap in place.
Old Jan 12, 2010 | 08:50 PM
BOTTOMS UP's Avatar
BOTTOMS UP
I used a regular t-sta in an all in one housing but it's been so long I can't remember the details as far as part numbers go.
I just tried one until it fit.
Old Jan 13, 2010 | 10:43 AM
aweil's Avatar
aweil
Good idea! I'll try that next time (hopefully there isn't one, lol!).
To LS Thermostats.. lower temp tip......
