spacers??
Old Jan 13, 2010 | 01:17 AM
Dennis Wilson's Avatar
Dennis Wilson
I remember seeing spacers a Pep Boys, I think they were a universal fit. Lots cheaper than $65 I wouldn`t go more than 1/4 in. with stock studs. Try googleing 'Wheel Spacers' & see what comes up.
Old Jan 13, 2010 | 10:44 AM
chevylad's Avatar
chevylad
You can also run an adapter plate with the same lug bolt pattern. If you are running any more than a quater inch spacer you will probably need either longer studs or an adapter plate.
You did not specify running a stock style wheel with acorn lugs or an after market wheel with shanks so I'm assuming you are talking about the stock style acorn nuts.
To spacers??
