Ls7 clutch, good stuff?
Old Jan 14, 2010 | 02:14 PM
99vetteran's Avatar
99vetteran
Default Ls7 clutch, good stuff?
Still undecided on the clutch setup. Will probably make a decision next week. I know that some of you guys have used it and was wondering what your opinion was and how much hp/torque are you putting down. Anyone spraying?
Old Jan 14, 2010 | 02:29 PM
aweil's Avatar
aweil
I have one in my C5Z with a heads/cam LS3. No problems, making mid 400 rwhp numbers. Buddy of mine with an '08 is making 650 rwhp on bottle with an LS7 clutch, doesn't slip but he does maintain the fluid.
Old Jan 14, 2010 | 02:44 PM
99vetteran's Avatar
99vetteran
They are pretty reasonably priced also. I'm making about 414 with a ****ty tune, I'll fix that in the next couple weeks.
Old Jan 14, 2010 | 02:47 PM
aweil's Avatar
aweil
It is my understanding that you need the LS7 flywheel or equivalent for proper spacing (I actually don't know the real reason but I assume it has to do with slave positioning on the torque tube and throwout bearing travel). The LS7 flywheel is HEAVY! You might consider getting an aftermarket lighter flywheel.
Old Jan 14, 2010 | 03:39 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
The stock LS1 flywheel is ~25 lbs, the stock LS7 is ~29 lbs.
Old Jan 14, 2010 | 03:56 PM
aweil's Avatar
aweil
For some reason 57 lbs is the number that stuck in my head... I did a little more research and that number is for clutch and flywheel. I stand corrected.
Old Jan 14, 2010 | 04:17 PM
99vetteran's Avatar
99vetteran
A friend of mine just put an ls7 in his, he did state if was about 4-5 lbs heavier. He has not had a chance to drive it yet, so, maybe I'll get some feedback from him. My ls6 clutch is much better since I changed out the fluids, its now clear again and before it looked really nasty.
Old Jan 14, 2010 | 06:19 PM
jpandes's Avatar
jpandes
I just had one installed a few months ago. My car is dynoing 451 rwhp & 405 ft.lbs. On the Stock LS6 clutch I started getting the lazy clutch pedal and slippage after I had new heads and a FAST 90/90 installed. That's even with meticulously maintaining clean clutch fluid.
Two reputable tuners in my area recommended the LS7 Clutch for a daily driven H/C car. One recommended going with the Fidanza AL Light weight FW and one recommended against going with an Aluminum FW, said it could cause clutch disengagement issues.
Since installation, I haven't had any clutch pedal issues at all. The pedal effort was a tiny bit stiffer than the LS6.
*One thing I would recommend is to have the clutch assembly "balanced" by a machine shop prior to installation. It will add to the cost and time to install it. Mine wasn't and I now have a very slight vibration coming from the clutch/fw. The tuner who installed it said that they just installed it right out of the box and that he normally doesn't balance LS7 clutches. He said that the vibration that I feel is "normal" and that it's not going cause any damage to the car.
Personally, I'd prefer that it wasn't there. Oh, well.
Old Jan 14, 2010 | 06:33 PM
LoneStarFRC's Avatar
LoneStarFRC
Any word from anyone on the ZR1 clutch? Feasable to use in a C5 platform?
Also, Monster is on the verge of releasing their first dual disc clutch and according to them, driveability is a major design point. They said it will incorporate dual 12" discs (IIRC) in order to increase total surface area and keep pedal pressures down and will use (if memory serves) organic material to eliminate chatter issues. They also said there will be a retro-fit package for people who already have some of their single disc units.
Old Jan 14, 2010 | 06:59 PM
99vetteran's Avatar
99vetteran
jpandes, did you end up going with the steel wheel instead of the lightweight aluminum? Sounds like if can handle the hp. Thanks for the info.
Old Jan 14, 2010 | 07:29 PM
jpandes's Avatar
jpandes
I went with the stock L2/7 steel fly wheel. I already had it and the tuner who installed it recommended it.
Old Jan 14, 2010 | 10:29 PM
Eric D's Avatar
Eric D
Did your tuner installer check the old flywheel for added weights that he could have transfered to the new flywheel?? No, vibration is not normal if it is more than what you had before the clutch was changed.
Old Jan 15, 2010 | 02:04 PM
VGLNTE1's Avatar
VGLNTE1
St. Jude Donor '14-'15
it will hold the power, but every c6z06 I know that drag races (stock) they still slip and the peddle still goes to the floor. so if you plan to launch hard or drag race often, go with something better.
my bud had a brand new one in his 422 c5 and ditched it after the first day at the track.
Old Jan 15, 2010 | 02:58 PM
jpandes's Avatar
jpandes
I now know it's not normal. But, I am not going to try and get the shop to uninstall it, balance it, and then reinstall it. That's 10+ hours labor. I think these clutches are "supposed" to be balanced from the factory. I'll just drive it and hope for the best.
Old Jan 15, 2010 | 03:03 PM
VGLNTE1's Avatar
VGLNTE1
They are, BUT....they need to be installed balanced
Old Jan 15, 2010 | 03:51 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
I had one in my car and it lasted a couple months before the pedal began sticking to the floor. The installer got lost on me, so I took it to ECS and had 3.90 gears and a new textralia clutch installed.
On the other side of that, a guy with the same set up as me with the same power had the LS7 clutch installed and it's been problem free for three years.
To Ls7 clutch, good stuff?
