Injector Install Instructions
Old Jan 14, 2010 | 05:37 PM
Speed Trap's Avatar
Speed Trap
Default Injector Install Instructions
I've searched the forum without success so thought I'd ask outright. I'm going to be changing my fuel rails so I will need to remove the injectors and reinstall them on the new "Chrome" fuel rail. Is it as simple as I think, in that I just pull them out of the manifold and the old rails, then poke them back in or is there more to it. I'm thinking that the O Rings are what holds them in the rails, correct? Should I lubricate the O rings with motor oil before installing them in both the rail and the manifold, or is there something else I should use?
Old Jan 14, 2010 | 05:49 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
Motor oil is what the manual recommends using. They just push into the manfold. Can't remember it there's a clip to remove on the fuel rail side or not.
Old Jan 14, 2010 | 05:58 PM
corvette8189's Avatar
corvette8189
Its as simple as you think, unscrew fuel rail and they just pop out of intake, make take a little force. To get the injector out of the fuel rail, i believe there is a clip u remove then pull out. Not hard to do.
Old Jan 14, 2010 | 06:18 PM
Todd157k's Avatar
Todd157k
Banned Scam/Spammer
yes, there's clips. and yes, they basically pop out however watch for the o-rings that sometimes stay on the injector, sometimes not. You'll have to dig them out of the fuel rail. Not hard, just watch for them.
I've attached a write up below which is for the oil sender replacement. You'll see (about 3rd or 4th page) the injectors, clips, and connectors.
Hope that helps.
Old Jan 14, 2010 | 08:12 PM
Patches's Avatar
Patches
Here's one I did a while back.
http://forums.corvetteforum.com/c5-g...tml?highlight=
Old Jan 15, 2010 | 12:32 AM
Speed Trap's Avatar
Speed Trap
Thanks for all the instructions. That will make it much easier.
To Injector Install Instructions
