Measuring push rod length
Old Jan 15, 2010 | 05:35 PM
corvettebob1's Avatar
corvettebob1
Default Measuring push rod length
Ok, somebody please tell me how I can get my fat fingers in between the rockers, springs and head to adjust the push rod.
I'm using a set of Patriot heads and Harland Sharp full RR on shafts.
Old Jan 15, 2010 | 05:51 PM
vettenuts's Avatar
vettenuts
I couldn't. I removed the rocker set each time and then made an adjustment. Find where it is too short, like 7.250" and open one turn at a time until it is too much then back off 1/2 turn, then 1/4 turn, etc. It will take several tries.
Old Jan 15, 2010 | 06:40 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
^ That's about it.
Although I was able to turn the adj. pushrod with it in place, but found the entire thing just spun instead of the top half of it unscrewing out. Gets you nowhere fast.
Ended up doing like vettenuts described.
Old Jan 15, 2010 | 10:25 PM
trackboss's Avatar
trackboss
While it is extremely tight it can be done without removing the rocker arm. I used both hands to grip each pushrod. The corners are the hardest. Make sure the threads on the pushrod are lubed and that it adjusts freely. Then make sure all lube is cleaned off both the pushrod and hands. Because its so hard to get in there this method is pretty much fail safe in terms of not getting the pushrod too long. It just cannot be extended more than zero lash with such limited grip. I simply went as tight as I could. To be sure I actually went through every pushrod and they all read damn near the same. Worked well for me. It's a good idea to call the lifter mfg. and find out what the recommended preload is. FWIW I used link bar lifters which are a huge improvement in drainage over the factory lifter cups.
Old Jan 16, 2010 | 12:08 PM
corvettebob1
Thanks guys, kinda what I thought......
To Measuring push rod length
