Two Tech Questions for Tech Experts
Old Mar 5, 2002 | 12:32 PM
WhiteSatin's Avatar
WhiteSatin
Default Two Tech Questions for Tech Experts
Corvette Owner Wanna-Be here (still saving so I can pay cash). If these questions have been asked before, please excuse me (I tried looking way back in the list and didn't see anything). First question: I want a FRC (or Z06) because I like the bodystyle, but I suffer from a physical defect that sometimes makes it hard for me to operate a clutch. My question is IF I had a FRC, and IF I had a doner car available (same model year but with an automatic trans) would it be possible to convert the FRC to automatic? Has anyone seen this done? Any idea how difficult it would be (generally speaking - not every tiny detail) Is this something that could be done in a well-equiped home shop, or would it require professional intervention? Second question (should be easier): Can the factory installed Body Side Moldings (BSM) be removed without damaging the paint? Are there any holes under the moldings, or are they just glued on? I don't like the BSM's and they would be enough to keep me from buying an otherwise "perfect" car, but if they can be removed, then they're not a problem. Thank you in advance for any answers you might provide, and I hope I can soon be a "real" member of this excellent enthusiast group.
Old Mar 5, 2002 | 12:38 PM
wstory1's Avatar
wstory1
Default Re: Two Tech Questions for Tech Experts (WhiteSatin)
Yes, I'm sure an FRC/Z06 could be converted to an automatic transmission given enough time and money. I'm not sure what would be involved but it could be done. BSMs are relatively easy to remove without damaging the paint. I believe people use fishing line between the BSM and the body to get the tape to separate and then clean up any remaining glue.
Old Mar 5, 2002 | 12:40 PM
DsC5's Avatar
DsC5
I know the BSM's can be removed relatively easily, there are no holes or anything. Just some glue I think. I'm not so sure about the trans, but I don't see why it isn't possible. Someone here will know for sure. I tend to prefer the hardtop style myself, but I didn't want a Z, nor did I want a used HT, so I wound up with a coupe. Best of luck to you. :seeya
Old Mar 5, 2002 | 12:50 PM
mac1009's Avatar
mac1009
I've been involved in a conversion of a '91 Mustang from an Auto to a Manual. From that experience, I can tell you that it's a PITA. The hardest thing was pulling the dash out to put the right pedal assembly in. The rest is fairly straightforward. Good luck with it and let us know what you decide on.
Welcome to the forum.
Dave
Old Mar 5, 2002 | 01:17 PM
WhiteSatin's Avatar
WhiteSatin
Thanks for the prompt replies. I'm glad to hear the BSM's will not keep me out of a deal...still not sure about the tranny, though.
Old Mar 5, 2002 | 02:29 PM
need-for-speed's Avatar
need-for-speed
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03 thru '10, '17
As you can see, I love the FRC. But if I were in your shoes, I would buy an A4 coupe before I would modify an FRC to that degree. I think it would be very costly. Even the computer program would need to be changed.
Old Mar 5, 2002 | 02:47 PM
David Lively's Avatar
David Lively
Some cars (I'm thinking of a Japanese model, but this may apply to domestic brands as well) have different mounting points for auto and manual trannys because of the larger size of the auto. Not to say that this couldn't be overcome, but I (personally) don't think it's worth the trouble, not to mention what this sort of conversion would do to your resell value.
Go with a coupe or a convertable; you'll thank yourself later.
Old Mar 5, 2002 | 02:48 PM
pridnjoy's Avatar
pridnjoy
Cruise-In III Veteran
Default Re: Two Tech Questions for Tech Experts (need-for-speed)
Another easier option would be to buy a convertible and get a hard top for it. Then you could have the best of both worlds! Best of luck in your future purchase.
Old Mar 5, 2002 | 03:03 PM
MitchAlsup's Avatar
MitchAlsup
The auto is not really strong enough to put up with the power (TQ) of the LS6 engine. Even in the LS1 engines, the computer backs down the throttle near peak TQ to keep the tourque levels from breaking parts in the auto tranies.
Since you are comitted to autos, why not avoid a big bunch of headaches and stick with the Coupe or Vert. The FRC was intended as a race-ready vehicle (as close as GM can get) from its inception.
Old Mar 5, 2002 | 04:04 PM
WhiteSatin's Avatar
WhiteSatin
Appreciate all the thoughtful replys. When I asked about the conversion, I figured it would probably be 1. to expensive 2. to much work 3. bad for the re-sale value of the car (although I do tend to hang on to cars, so that is not as critical). I do like the idea of adding a hard-top to a convertible. I have owned other 'verts with aftermarket hard-tops (MGB, 280SL Mercedes) and found them to be an excellent compromise. I was not aware that there were tops available for the C5, but thanks to "pridnjoy" I have already discovered that Smooth Line makes one, and there may be others. The only problem with a convertible is you pay a hefty premium in price, especially if you don't really care about going "topless". In the end, I will probably end up with a coupe, and be very happy to have it. Thanks again for all the responses.
To Two Tech Questions for Tech Experts
