Dumb question- need help with Ctek install
Old Jan 16, 2010 | 12:59 PM
WildWolf's Avatar
WildWolf
Default Dumb question- need help with Ctek install
So I am trying to install the "permanent" clips onto my battery but the posts are thicker than the clips that came with the Ctek. What can I do about this?
Old Jan 16, 2010 | 01:05 PM
lucky131969's Avatar
lucky131969
Not familiar with the Ctek, but after a quick search...I only found alligator "clips", and the permanent install was a harness with ring terminals.
Do you mean the ring terminal eyelets are too small for the diameter of the battery cable bolts?
Old Jan 16, 2010 | 02:22 PM
hotwheels57's Avatar
hotwheels57
Use of the ring terminals is more "permanent" than the alligator clamps. If the original ring terminals ID are to small, larger terminals are as close as your favorite hardware store, auto parts store or RADIO SHACK.
They can be crimped or soldered. Then you can add small sections of red or black shrink tubing to cover the insulator on the ring terminal and identify the positive from negative. Do one at a time so you don't confuse the polarity.
Old Jan 16, 2010 | 02:58 PM
WildWolf's Avatar
WildWolf
thanks. I will go to radio shack.
Old Jan 16, 2010 | 03:10 PM
vettenuts's Avatar
vettenuts
I found that I had to remove the plastic pieces from the alligator clips for them to fit well. I painted each clip black and red to make it easier.
Old Jan 16, 2010 | 04:20 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
I use the clips. I just know one day the kids will trip over the cord and pull it from the battery. I figure the clips will for the least damage
To Dumb question- need help with Ctek install
