seat back hoop installation
Old Jan 17, 2010 | 03:50 PM
tom hatten's Avatar
tom hatten
Default seat back hoop installation
just receive seat abck hoops from east caoast corvette i have seen threads in past stating you can bolt these in with 3/4 inch self tapping screws has anyone does this succesfuly and how-also anyone have or know of template or instructions on cutting carpet any help appreciated thanks
Old Jan 18, 2010 | 03:08 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
I'm not a fan of the look, don't tap those screws into the fuel tanks, I've seen horror stories on that in the past
Old Jan 18, 2010 | 08:58 PM
Awsum98's Avatar
Awsum98
Default seat hoops
I have installed at least 7 sets of the hoops with the 3/4 inch screws without any problems and I started with my own vette as seen here. if you want to make sure you don't hit the fuel line drill a small hole then stick something in it till you hit the crossover pipe,,you'll have over
1 1/2 inches of space to play with !! I used washers with the screws and have been on my vette for over 5 yrs. now and they will not get loose.
Old Jan 20, 2010 | 01:25 PM
tom hatten's Avatar
tom hatten
Default seat back hoops
did you use all holes provided or a select few including top and back thanks for your time and response
Old Jan 23, 2010 | 12:38 AM
sbadd99's Avatar
sbadd99
I used a 2 pack epoxy as solid as
Old Jan 23, 2010 | 12:11 PM
99 vett babycar's Avatar
99 vett babycar
works great - NO HOLES.
Old Jan 23, 2010 | 07:13 PM
Awsum98's Avatar
Awsum98
Default seat hops holes
I used a screw in every hole on the hoop !
no problems at all.
Old Jan 24, 2010 | 08:02 AM
tom hatten's Avatar
tom hatten
no problems at all.
thanks for your interest in my project seat back hoops installed saturday and after doing this the way i wanted to and you suggested i really dont understand why anybody would want to epoxy them in by going slow as suggested drilling small pilot hole and using small pick to feel around i had all kinds of clearance also by screwing them in you can tune the adjustment and shim if necessary they are also solid as a rock 1 thing nobody mentioned at least on my vert there is a pretty good sized weld back there thick weld did hamper the left lower mount bolt on both hoops and because of that i did have to shim any way thanks again and me personally would never want to epoxy these in thanks for giving me the courage to do it your way again thanks tom
Old Jan 24, 2010 | 02:07 PM
c5vetteguy's Avatar
c5vetteguy
2018 C5 of Year Finalist
Tom, exactly what size screws did you use, and are these sheet metal screws?
Old Jan 24, 2010 | 03:25 PM
tom hatten's Avatar
tom hatten
1/4 x 1" self tapping sheet metal screws with flat washers of course started out with drilling 1/8" pilot hole thanks again
To seat back hoop installation
