Shim Availability
Old Jan 17, 2010 | 07:45 PM
Its_Go_Time's Avatar
Its_Go_Time
Default Shim Availability
It's a long shot, but does anyone know if there is another source other than the dealer for the shims used to preload the differential bearings? It would be nice if someone sold an assortment pack, so you'd be assured of being able to make the right stack without having to stop and special order individual shims.
This is what I'm talking about:
Old Jan 18, 2010 | 02:58 AM
SJPD's Avatar
SJPD
any shop that rebuilds rear ends should have them
usually an assortment comes with the rebuild kit
Old Jan 18, 2010 | 07:29 AM
dougbfresh's Avatar
dougbfresh
Try Summit
Old Jan 19, 2010 | 08:49 PM
ragtopws6's Avatar
ragtopws6
Those are a precious commodity! Unless you have diff cores laying around, I don't know any vendor/company selling those other than GM. Ask me how I know......
Old Jan 19, 2010 | 08:50 PM
BOTTOMS UP's Avatar
BOTTOMS UP
how do you know ?
Are they an oddball diameter ?
Old Jan 19, 2010 | 09:15 PM
ragtopws6's Avatar
ragtopws6
I get all my trans/diff parts from RPM. Rodney would part with most things he has around the shop but NOT the side shims! LOL. I also have called, emailed most of the diff companies I could find on the net and they do not have any. So 2 sources, cores or GM.
Old Jan 19, 2010 | 09:31 PM
Its_Go_Time
I like people with soild answers! GM wants about $4.50 a pop, so I guess I measure twice, then special order.
Thanks for the replies!
Edit: Solid answers are also accepted.
Old Jan 19, 2010 | 09:32 PM
JVetthead's Avatar
JVetthead
When i did mine I found a 4wd shop that had some.. I guess they are the same as some transfer case or truck diff... could not find 'em anywhere else.
To Shim Availability
