remote will not resync?? help
Old Jan 18, 2010 | 01:49 PM
00transamls1's Avatar
00transamls1
Default remote will not resync?? help
I have a 98 c5 replaced the battery on my remote and tried to resync it using the dic when I get the the un+lock button hold down together on the fob screen it wont do anything. I got to do something because it makes me nervous not having a alarm on my car and annoying having to use the key everytime. passive not working either. the remote does have a little rattle in it I took it apart to see if anything is loose but didnt see anything.
Old Jan 18, 2010 | 02:24 PM
LiteraCola's Avatar
LiteraCola
Interesting...I have the same problem. But replacing the battery and resyncing it worked...although whenever the fob is near the car, the horn honks once every 15 seconds or so. Kinda annoying. I'm not sure how to fix it either...
Old Jan 19, 2010 | 07:20 AM
00transamls1
Looks like that worked for a lot of people I will have to try it. I dont see and points loose but Ill reinforce them and see
Old Jan 19, 2010 | 10:32 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
You should try sliding the passive switch on and off several times. Pocket dust seems to get in there or whatever, causes it to turn the passive function on.
Old Jan 19, 2010 | 11:09 PM
Carcass's Avatar
Carcass
That little rattle is normal,at least on a fob with the passive feature.
Are you sure you're synching the fob(s) correctly?
KEYFOB PROGRAMMING:
1) Turn ignition on
2) Turn radio off
3) Press Driver Information Center (DIC) RESET button ( 6 )
4) Press OPTIONS button on the DIC until display is blank ( 4 )
5) Press and hold RESET button for 3 seconds ( 6 )
6) Press OPTIONS button until FOB TRAINING is displayed ( 4 )
7) Press RESET button to begin programming sequence. ( 6 )
8) Simultaneously press and hold LOCK and UNLOCK ( A & B )
buttons on first remote for 13 seconds until message
appears stating programming is complete. The computer
will ask to program second FOB. If you don't have a second
FOB follow on to step 9.
9) Turn ignition off and remove key for ignition.
10) Test remote or remotes
Old Jan 21, 2010 | 05:52 PM
00transamls1
yeah I did it correctly when I get to the unlock + lock screen it doesnt change until is exits two mins later
Old Jan 21, 2010 | 06:21 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
Is that the original remote for your 98?
If you've tried everything and it still won't work usually buying a new one will solve your problem.
One other thing, make sure your car battery is fully charged. It can affect the remote programming.
Old Jan 21, 2010 | 06:35 PM
00transamls1
Im not for sure if it the original but im just going to have to break down and get a new one. anyone cheaper than dealer for a new remote.
Old Jan 21, 2010 | 10:56 PM
hotmerc's Avatar
hotmerc
I just bought a brand new one & it still won't work. I'm hoping to find someone with a known good one & borrow it & try to resync. I would hate to buy another new one & find out I have other problems.
Old Jan 22, 2010 | 08:36 AM
00transamls1
thats what im hoping is not going to happen
Old Jan 22, 2010 | 10:54 AM
dgrant3830's Avatar
dgrant3830
Gene Culley has the best price around as far as I've seen. www.gmpartshouse.com
Old Jan 22, 2010 | 02:32 PM
hotmerc's Avatar
hotmerc
I bought a brand new one from Gene, tried to reprogram & nothing. I'm hoping I just got a bad new remote.
Old Jan 23, 2010 | 08:15 AM
00transamls1
its got to be the remote cause I went to a local auto shop and they have a remote tester and it came nothing. looks like ill be buying a new remote. I looked at the link I didnt see it listed. anyone know what he changes?
Old Jan 26, 2010 | 07:30 AM
00transamls1
I went a head and bought the 00 remote from there so we will see if it was just the remote
Old Jan 26, 2010 | 07:18 PM
hotmerc's Avatar
hotmerc
My problem ended up not being my new remote, but my pathetic comprehension abilities. I was stopping 1 step short in the relearn procedure.
Old Jan 30, 2010 | 01:47 PM
00transamls1
replaced the battery and nothing I soldered it and it works now but only a distance of two feet or closer to the car. im going crazy. I tried to resync the remote and held it for the 15 second and it never showed it was sync but locked the doors hahaha its wild
Old Feb 7, 2010 | 03:57 PM
Trog's Avatar
Trog
I'm working on a 2000 FRC & the DIC won't go into the learn mode... It gets to the Tire Learn & when you press options again to get to Remote it doesn't do anything. I went ahead & even trained the tire monitors to see if it might step forward on its own but didnt. I even pulled the remote box & checked the connectors... all appears fine. I also tried using a tech 2 but that isn't needed until 2001.
Old Apr 7, 2010 | 02:03 PM
ddemien's Avatar
ddemien
1st Gear
I followed the step above. Everything went according to plan, the message center said FOB was programed, but when I tested FOB it still didnt do anything.
Any thoughts??
To remote will not resync?? help
