I wasn't aware that Hooker made headers for C5's, but if they are shorty headers, unless they're dirt cheap or free, they probably aren't worth the expense or effort. If they are long tubes then that's a different story. The only other thing is that I recall that their exhausts were painted tubing, not stainless steel, which wouldn't last as long or stay good looking for long either. Personally, I'd pass get a long tube and exhaust system from another more well-known for C5 exhaust systems company, like LG (which I have), ARH or another.
Depending where you live (calif for example) LT's are NOT smog legal--so you are stuck with shorties---As mentioned shorties are really only good for about 8-10 RWHP---Whereas a set on LT's can produce Hp in the 18-28 range---ALSO---Without proper tuning you may in fact get little or NO HP gains with the LT's---It's almost mandatory to get it tuned after a LT install to get the full benefit of them---
ALSO---In a smog state the LT's are illegal because they change the "closed loop" or part throttle AFR----The commanded AFR in CL is 14.68-1 BUT because of the now further back locations of your 02 bungs you get erroneous 02 readings---It makes the engine run richer--I've seen something in the 14.1 to 14.4 range-- Shories use the stock 02 bung locations that's why some of them are smog legal IF they went thru the cerification process which is very expensive--
You will get a good gain with long tubes even without a tune. A tune is not manditory.
I went from a 13.33 to a 12.93 at the track with just long tubes no tune with my Stock auto SS.
I got American racing headers on my vette and noticed a big gain and i have no tune yet.
Personally I would stay away from hookers do to quality. There ceramic coat will rust quickly down by the collector. If you are looking for a bargain on headers try the used section or pacesetters over the hookers.
Don't limit yourself to what your auto parts store can get you, you might be passing up better parts and good opportunities. There is mail order and the better companies are good to deal with and no problems getting your parts. For instance, LG sometimes runs sales on their header systems complete with the entire exhaust system minus the catback muffler part, even occasionally free shipping. Since you don't show where you live it's hard for anyone to refer good vendors that might be convenient to you. American Racing headers and Kooks also have excellent reputations. You also haven't mentioned if you can run long tubes where you live. If you can, they are definetely worth the difference in price over shorties for the difference in performance they offer. You install a good total exhaust system, get a top quality intake and have your car tuned and you will really feel the difference in the *** meter. Spend right and spend once!
I assume you mean a SS camaro ?? If so, an f-body doesn't have very good factory cast exh manifolds--- a C5 has mush better flowing STOCK exh manifolds----SO a set of LT's would respond better to an F body "untuned" then they would to a C5 "untuned"---I have tuned a stockish C5 with New TSP LT's on a dyno----Untuned it only made 8 RWHP over stock----after 2-3 hours of tuning the fuel and timing we got an awsome 31 RWHP gain-----
Just curious...did you happen to note what your AFR was before and after the tune?
My C5 made over 20 HP more with LTs, and it was completely untuned. I recommend to the OP LG Street system, or ARH. Third choice would be Dynatech or Kooks. Your Borla exhaust is merely for sound quality/quantity, and won't affect your power output much.
What typically happens is that the closed loop fueling (part throttle) goes way lean so the ECM ADDS fuel when going to PE or WOT---
Remember that whatever the LTFT's are just BEFORE going into PE or WOT is ADDED to your WOT fueling usually around 10-15 %--- A negative fuel trim locks on "0" and will never subtract fuel at PE or WOT---So it's always best to get all the trims "0" or slightly negative---I can't remember exactly but i think before correcting the LTFT's it was in the 11.9 range ( checked with a wideband) And after the trims were fixed the fuel at WOT was rich----around 12.2--So I leaned the PE table to compensate and endind up with a finall street frinedly 12.6 or 12.7
I ordered Bassani Longtube Headers, and Borla Exhaust to go with my K&N Intake
Next I'm going to get a Mail Tune..
Bassani and B&B both make good quality products. The two most popular manufactures of LT's on this forum are ARH and LG which are both top notch products. The Bassani and B&B headers don't have the popular support,but I bet if the four headers were dynoed on the same engine that the performance differences would be minimal.
Thanks for responding. I never understand the guys who spend the money for headers, and don't follow up with a tune......just leaving HP on the table.
There was a thread quite recently of people who had Bassani headers. In theory, while the tri-y headers don't make the most all out horsepower, their mid-range torque should be greater than a 4-1 header, which is where you spend most of your time. The drawback of the Bassanis, as stated by people who used them, and generally they are in the header minority, is that they are multi-piece header tubes and become a problem with leaks at the joints. I think you should check into this before you confirm your purchase. Otherwise, good luck!
BTW, if you have a tuner near you it's always better than a mail-tune. If you must do a mail-order I'd recommend East Coast Supercharging.
