heater control lighting
Old Jan 20, 2010 | 12:42 AM
bobnjudy's Avatar
bobnjudy
Default heater control lighting
The lighting has died in my heater control. It appears to be illuminated with LED's.Is it possible to repair it? If so where can I find replacement LED's?
Old Jan 20, 2010 | 02:19 AM
Blown 346's Avatar
Blown 346
You can repair it, but you might have to re solder the contact points. Once you find what size LED's you have,Ebay has tons.
Old Jan 20, 2010 | 05:31 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Is it the display or the buttons?
Old Jan 20, 2010 | 08:55 AM
bobnjudy's Avatar
bobnjudy
It is the buttons and back lighting. The display is still working, and the heat and AC are working normally.
Old Jan 20, 2010 | 10:51 AM
dankhts's Avatar
dankhts
There was a forum member who repairs them good as new...ship it off to him, and he'll send it back all done.... maybe somebody remembers his name?
Old Jan 20, 2010 | 12:07 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
That would be us
Old Jan 20, 2010 | 01:01 PM
bobnjudy's Avatar
bobnjudy
The car is my daily driver so I would not want to keep it apart for days. If I can't pull it out, solder some new LED's in it and put it back in, I will
wait until it annoys me enough to replace it.
Old Jan 20, 2010 | 01:35 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
They are not LED's for the switch and background lighting. Forum member Tstar has all the info on the lamp requirements, typically a 70ma 12 vdc will provide the correct brightness.
Old Jan 20, 2010 | 01:44 PM
tiojames's Avatar
tiojames
A friend of mine has the same problem and in a post not long ago some one said they fixed theirs by rapping on the area. I e-mailed my buddy and he said it works for anywhere from a day or two to a couple of weeks before he has to bang on it again. I think it has to do with a bad connection and the jarring gets it going again.
Old Jan 20, 2010 | 07:51 PM
dgrant3830's Avatar
dgrant3830
That might work if the lamp's filament connects itself but its going to fail again.
Old Jan 20, 2010 | 10:22 PM
bobnjudy's Avatar
bobnjudy
OK thanks. I had it apart a couple of months ago and did not see anything that looked like lamps. but I will take it apart again and take a closer look. At that time it was a couple of buttons and the illumination behind the DS control. Since then the PS dial went out and the only button left working is the AC button. I would suspect a connection if they all failed at once, but it has happened over 6 months.
Old Jan 21, 2010 | 10:51 AM
dgrant3830's Avatar
dgrant3830
I don't remember the total count but it was like 11 of them or similar. Replace them all. Send a PM to Tstar and he'll advise on the lamps. If not, let me know because I have a source that I used and they worked great but involve a little more effort.
Old Jan 21, 2010 | 07:28 PM
tstar's Avatar
tstar
14 total and replace all of them at once... I use these;
http://www.mcmaster.com/#1505k414/=5h6pah
Tim
Old Jan 21, 2010 | 10:16 PM
bobnjudy's Avatar
bobnjudy
OK Thanks for all of your help.
To heater control lighting
