Injector upgrade needed with bigger cam?
Old Jan 21, 2010 | 06:15 PM
94brick's Avatar
94brick
Default Injector upgrade needed with bigger cam?
I have pulled the trigger on a new cam for my 02 Z. I am now gathering the other parts for the job and the question of upgrading to larger injectors has surfaced. I am hoping to be around 400-420 rwhp when all said and done. Again just cam and full exhaust at this point, no heads or intake. With that said am I still within the stock Z06 injectors limits? In my last search I read perhaps that 450 rwhp was the limit of stock injectors. Comments appreciated.
Old Jan 21, 2010 | 06:57 PM
Brandon619's Avatar
Brandon619
You will be fine with your stock injectors but I would optimize your cam with a set of good heads and a FAST Intake and 90mm TB but thats just me
Old Jan 21, 2010 | 07:09 PM
Blow Torch's Avatar
Blow Torch
You should have plenty of injector with a cam change I did H/C and all bolt ons and didn't have to upgrade
Old Jan 21, 2010 | 07:25 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
I have a 237/242 .609 MS3 in mine and Im still using stock LS1 injectors. 413rwhp cam only.
Old Jan 21, 2010 | 07:44 PM
94brick's Avatar
94brick
I appreciate the responses. But what did you base your answers on? What where your duty cycles with the mods mentioned above?
Old Jan 21, 2010 | 10:30 PM
0331MARINE's Avatar
0331MARINE
Cant remember the number, but I have LT's no cats, CAI, stock intake manifold, and 241 heads with dual springs, hardened push rods. I know I was no where near 100%. They told me I could still do heads and intake manifold and be fine with the stock ones.
Old Jan 22, 2010 | 12:32 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
With just headers, ported TB and a VARARAM and a tune, my 02 ZO6 was making 390 RWHP 375 RWTQ, injector duty cycle was in the 100-103% in the upper RPM band at WOT.
I went with 42's for my heads / cam / ported fast 90 / ported 90mm TB VARARAM and my duty cycle are in the mid 40's. 36's would have worked perfect. Now I'm making 450 RWHP
Unless you have a big cam and ported manifold to help it get more air, 36's would be what you need.
Old Jan 22, 2010 | 01:29 AM
OhioC5's Avatar
OhioC5
Bill, you think COT could have been the reason for 103% duty cycle? My 02 has long tubes, CAI and exhaust and I was at 98% duty cycle. I disabled COT, need to look through my logs but I believe the duty cycle was down in the 70%'s. A friend of mine suggested this change in my tune, it seemed to be the key.
Old Jan 22, 2010 | 09:26 AM
94brick's Avatar
94brick
This is the part the confuses me and must be due to other car variables.
0331MARINE- gets reports of no where near max duty cycle with a few mods.
Bill Curlee- less mods and and yet over 100% of cycle.
So what are the variables to account for, COT, what about engine miles as I only have 15K?,
Old Jan 22, 2010 | 10:32 AM
dougbfresh's Avatar
dougbfresh
The only way to know is on the DYNO.
Old Jan 22, 2010 | 11:49 AM
GFCmgb71's Avatar
GFCmgb71
I have an '02 (non-z06) and put some z06 heads and a G5X3 cam in along with some headers, a vararam, and underdrive pulley. my stock injectors were at 120% duty cycle at WOT. I have no numbers as the car was street tuned. IIRC your injectors should be around 80-85% duty cycle at WOT. that way you have alittle room to grow also. i put 38lb injectors in and the car flies! BTW compression is at 11.5:1
Old Jan 22, 2010 | 02:22 PM
wfdlt8's Avatar
wfdlt8
Are your heads milled to get that compression ratio, or did you use thinner head gaskets?
Old Jan 22, 2010 | 03:19 PM
GFCmgb71's Avatar
GFCmgb71
Heads were milled .01 and thinner head gaskets were used (don't know the exact thickness)
Old Jan 22, 2010 | 03:56 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Or street, or track. Wherever you can reach hp peak while logging IDC.
Assuming the car will get tuned after the cam swap, the tuner will be able to tell you right away if you need to upsize the injectors or not. The stock ones usually max out around 410-420rwhp.
If you do need more injector, the red top 30# SVO injectors will more than suffice, and will support over 450rwhp.
Old Jan 22, 2010 | 08:43 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
If your asking will your injectors still work, Yes they will still work with 420 RWHP. Cruising around time, you wont have much of an issue.
Will they work properly at WOT. No. At WOT you will clearly be over your usage rate for your 28.8 injectors.
Would you put in undersized springs for your new cam?
I had 28.8 injectors in when I was at 425 RWHP, and I was getting 110-112 usage rate at WOT. Your safe if your injectors run at 80-85% at WOT.
pick up some ford 30# injectors and keep your motor happy
It will be easy for your tuner to tell you what your duty cycle is when your car is getting tuned. But then when you see your under injectored and go out and buy new ones, your tuner may bang you a couple more bucks for a touch up tune and rescaling of yout injectors
Old Jan 23, 2010 | 12:10 PM
94brick's Avatar
94brick
Yep, good advice. 30 # injectors will keep things safe.
Old Jan 23, 2010 | 06:51 PM
2079's Avatar
2079
I purchased these Ford # 30 injectors ,they are red, for my H/C ....I read on an other post "after" that they are like # 38 on our cars ? Please explain.
Thanks Lucien
To Injector upgrade needed with bigger cam?
Old Jan 23, 2010 | 08:08 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
Thanks Lucien
Closer to 36#
An injector flow rating is always relative to fuel pressure.
Most injectors are flow-rated at 3bar (43.5 psi) fuel pressure. But C5 fuel system runs at 4bar (58psi).
So, given an injector rated to flow 30# @ 43psi...Used at 58psi, it is actually a 36# injector.
This is why those "little" 30s are good for so much more hp over the stock 28.8s. (which btw are rated 28.8# @58psi).
Old Jan 23, 2010 | 09:00 PM
2079's Avatar
2079
Originally Posted by Y2Kvert4me
Closer to 36#
Great info for many of us.....I'm keeping this on file to help others in the future. Many thanks.
Old Jan 24, 2010 | 09:57 PM
marc rud's Avatar
marc rud
Default 33#injectors from C6 in 99' LS1 C5.
I am using C6 90mmTB, intake, and injectors..33#'s I believe... Anyone using these on their C5??? What kind of power will they support???
Is it worth it to have them sent out to have them flow matched, and if so who to send them to...? What does Mr. Curlee think about this combo? Going to use a Mayhem II cam, both TB and LS2 manifold are ported.
Thanks,
Marc
