Bent Rod Ls-1
Old Feb 2, 2010 | 01:38 PM
  #41
lucky131969's Avatar
lucky131969
Am I looking at the pic right? Is the roller toast?
Old Feb 2, 2010 | 02:15 PM
  #42
Rconce01's Avatar
Rconce01
Originally Posted by dougbfresh
Did you actually check the valves for being bent?
yes i removed the keepers and pulled them out they are all straight and the springs are good too. they move freely in the guide.
This is my theory for the past 100 miles or so i've been hearing a sound a weird sound like metal on metal. I think that roller on that lifter was starting to lock up far before i ever reved the car the day that i busted the rod. Slowly i am sure the roller got more and more stuck eventually flatting it out, and when my dumb *** reved the car the roller might have decided to roll pas the flat part causing excessive lift and a busted rod and a cracked guide.
  #43
Rconce01's Avatar
Rconce01
you are right on! it's flat to the bone.
Old Feb 2, 2010 | 02:21 PM
  #44
dougbfresh's Avatar
dougbfresh
Still does not make sense. If the lifter was stuck in 1 position like that, it should aloow less and less lift as it wore. If it did finally move, it should not have lifted the valve train any highr than a normal lifter. I'm betting somethin bound up on eithe the valve or the spring putting too much pressure on the lifter till it fialed internally making it act like a solid lifter-still hard to believe a valve or piston didn't have an issue here-to bend that pushrod, something on the valve side had to hang up while the cam was trying to open it.
Old Feb 2, 2010 | 07:11 PM
  #45
ragtopC5's Avatar
ragtopC5
I had a roller tip lock up on one of my lifters. Had the same squeak you mentioned. Drove the car about 150 miles like that because it happened when I was out of town and I wasn't sure what was wrong.
Any way, if the cam lobe is not polished any more I would replace it. Mine looked ok but measured .001" less lift when I pulled it out of the car. The surface finish is very very important here and you will be pulling the engine apart in another couple thousand miles with the same lifter gone bad if you don't replace it now.
Old Feb 2, 2010 | 07:15 PM
  #46
lucky131969
Yuck. So the cam is trashed too.
Old Feb 3, 2010 | 10:06 AM
  #47
Rconce01's Avatar
Rconce01
Oh wow did your roller end up flat like mine? Did you have to yank it out with a locking pliar like me too?
Old Feb 3, 2010 | 01:54 PM
  #48
kh400's Avatar
kh400
I don't have the equipment to do it. I need to buy those gauges first to be able to do the test and get a compressor.
The car idles just perfect man, i've been in cars with bent valves and for starters they idle poorly.
The intermittent squeak is definitely coming from exactly the area that had the worse bent rod, and its consistent with the rpms. I just stopped running it for now and when i pull the head out i will look for any signs of the valves contacting the piston and also check all those rollers and make sure they are rolling with no damage.
I think it's possible that you have a valve that is seizing in the valve guide. That would explain the intermittent squeal and the bent push rod. Just my two cents. Good luck.
Old Feb 3, 2010 | 02:31 PM
  #49
dougbfresh's Avatar
dougbfresh
That would make the most sense.
Old Feb 3, 2010 | 03:33 PM
  #50
Rconce01's Avatar
Rconce01
I thought of that and that's why i pulled the valve out and checked that it wasn't bent or binding within it's guide.
Can it still get stuck despite the fact that i checked that its moving freely within its guide?
Old Feb 3, 2010 | 03:58 PM
  #51
dougbfresh's Avatar
dougbfresh
How did you check the valve for straightness? Bet it's a little bent. If it was binding, that would explain the wear on the lifter. Something hung up solid to bend that pushrod.
Old Feb 3, 2010 | 04:09 PM
  #52
Rconce01's Avatar
Rconce01
I checked it with a steel straight edge, additionally I spun it around by hand within its guide and against the seat and its good. Once i put the keepers on it it seals great.
I am not the brightest guy but I've had my share of automotive education.
Old Feb 3, 2010 | 07:03 PM
  #53
Rob's 73's Avatar
Rob's 73
My 2 cents:
The motor was over rev'd and you tagged the pistons. I think I see a on the piston. Look close. Then you bent the push rods (I count at least three. With no spring pressure on the lifter (no way that severely bent rod was long enough to reach the rocker while the cam was on the base circle) the cam started beating the crap out of it and the lifter tray.
New cam, push rods and lifters....all 16. Hopefully the lifter bore isn't jacked!
Old Feb 3, 2010 | 07:33 PM
  #54
Rconce01's Avatar
Rconce01
Well thanks to all of you for your time and expertise!
I've inspected it real close and I still don't buy the fact the piston hit the valve.
As soon as the parts come in I am reassembling and firing it up.
Old Feb 4, 2010 | 01:01 PM
  #55
kh400's Avatar
kh400
I was wondering how the oil pressure is on this engine and the oiling to the top?
Old Feb 4, 2010 | 02:25 PM
  #56
Rconce01's Avatar
Rconce01
honestly it looked pretty well oiled, all the rockers and the push rods had plenty of oil. The valve and the valve guide was dry, but that's normal since the valve stem seals are supposed to keep the oil out of there.
thanks!
Old Feb 10, 2010 | 03:13 PM
  #57
Rconce01's Avatar
Rconce01
Got the lifter trays i was waiting on last night and reassembled everything and its running sweet.
To Bent Rod Ls-1
Old Feb 10, 2010 | 03:19 PM
  #58
lucky131969
Did you replace the cam?
Old Feb 10, 2010 | 03:39 PM
  #59
Rconce01's Avatar
Rconce01
Actually, I didn't. The cam lobe was getting the same amount of lift on that lifter. The surface of the cam was not polished but it wasn't pitted or irregular. I got my finger in there and felt it. I replaced all the lifters on the passenger side and torqued the head down and reassembled it.
If the same thing happens again i'll swap that engine out for another one i have. I hate dealing with with these valve train issues.
The amount of time/ money it would have taken to swap the cam and both heads is something this engine isn't worth.
Its at 160k
Old Feb 10, 2010 | 03:45 PM
  #60
lucky131969
Its at 160k
Oh. Hard to believe, as worn as that lifter was, that the cam emerged unscathed. Well....good luck
