I did search and i ended up reseting some codes and it went back to normal, but why? Bascially i had a little under half a tank last night. While i was parked with car running the check guage light came on along with my gas needle going straight to empty. I did reset the codes and it went back to normal but why? This was the code that says History and Current (P1431 Fuel Level Sensor 2 Circuit Performance)
Mine did that once about a year ago-Now I run a jug of Techron through it every 4th tankful,and it's never done it again.
To answer your question,It is caused by sulfur deposits building up on the sending unit inside the tank-the Techron seems to either get rid of the deposits,or at least keep them at acceptable levels,so the sending unit can operate properly.
I wouldn't worry about it yet-if it keeps doing it after the Techron,then you can start to worry...
I agree, Techron works very well, I put a 20 oz bottle in about three times a year.....never have an issue, seems to add some zip as well...sorta like Gatorade after a golf game.
I actually seafoamed the car back in Feb of 09 when i 1st bought it. Barely any smoke came out which was a surprise to me. I will run techron in it and see what happens. But after the code reset it went back to normal. Have no driven it yet, but ill keep this thread updated.
Yep, just get used to resetting the code and you can drive it just fine. Many people don't realize you can reset the codes to fix the needle and they drive around with the tank on E until the Techron does its' thing. I used to get it all the time and just religiously used one brand of gas at a time until I found one that didn't produce the codes. I've been using Shell for 2 years now and never had the gauge go to Empty. Before using Shell probably happened to me 40+ times. No Chevron stations here which is another brand well known for eliminating the gauge going to empty issue.
^^^ Aww ok yea. When i did the seafoam, yes, i added it to the tank as well as the oil. Ill keep that in mind. I should prob pick some up now since i have half a tank left.
Add techron (Seafoam seems to be a "nuclear" option but it also works.
Clear the codes
Switch your brand of gas. Chevron has Techron added so its a good choice as is Shell.
FWIW, I read an article by a fuel scientist who reckoned that different additives have different characteristics that fix specific issues. That said each type of fuel can add deposits that its additive doesnt clean. So switch brands every so often and it may work different problems.
Bottom line is that sulfur is our main issue here.
If Seafoam and Techron do not work for you then you are up for a right side fuel tank sensor replacement and possibly a right side fuel tank replacement.
My 01 kept repeating the problem after several tries with Seafoam and Techron. Finally had the shop replace the sensors. More problems ensued and that is when the dealer dropped the enchilada on me about the fuel tank being replaced.
If it gets to the point that Seafoam and Techron do not cut the mustard then be sure to have a peek at #PIC3725A available at your local Chevy dealers. It applies to 1997 through 2002 year models including 2003 without RPO FFS.
Yeah it sucks.
that the tank change is the ultimate option. OK if you have extended warranty. I'd hate to see everyone here with a sticky gas gauge go that far though.
I'd use a lot of Techron first. I'd also change the fuel sender. You can do that without dropping the tank. Theres a DIY thread here somewher. A tank change would be beyond me so that would be serious $$$
What I noticed exacerbates the problem is parking the car with tank less than half empty....soo DO NOT park your car with tank empty....don`t know what the relation between the tank empty and gage going bad but I could swear that in my case if I do that my gage would go to empty right away
its $1700 for a right side fuel level sender module and right side tank. Mine was just done on friday. I picked it up yesterday afternoon, 110 miles later,... fuel level went to empty again and threw the code. I'm glad carmax is picking up the tab
Originally Posted by crAzy03Z06
I use Shell and Chevron nothing else.
Texaco also has the same level of Techron as Chevron. They have been the same company for awhile now. Chevron-Texaco.
Look on the lower left of the Texaco pumps for the Techron logo.
