key fob training
Old Jan 24, 2010 | 02:30 PM
evildave's Avatar
evildave
Default key fob training
have tried via the DIC and the user manual instructions, once i cycle through the options menu until the screen goes blank i hold the reset button in and nothing happens at all, any ideas????
Old Jan 24, 2010 | 03:20 PM
65GGvert's Avatar
65GGvert
I'm not sure you're doing step 6. After you hold the reset for 3 seconds, are you pressing options and scrolling to "fob training"? Are you turning the key to "on" (not acc)?
KEYFOB PROGRAMMING:
1) Turn ignition on
2) Turn radio off
3) Press Driver Information Center (DIC) RESET button ( 6 )
4) Press OPTIONS button on the DIC until display is blank ( 4 )
5) Press and hold RESET button for 3 seconds ( 6 )
6) Press OPTIONS button until FOB TRAINING is displayed ( 4 )
7) Press RESET button to begin programming sequence. ( 6 )
8) Simultaneously press and hold LOCK and UNLOCK ( A & B )
buttons on first remote for 13 seconds until message
appears stating programming is complete. The computer
will ask to program second FOB. If you don't have a second
FOB follow on to step 9.
9) Turn ignition off and remove key for ignition.
Old Jan 24, 2010 | 06:03 PM
hotmerc's Avatar
hotmerc
Man I've been fighting a new Fob reprogramming issue for a couple of weeks. Now I feel like a big ole dummy, need to read a litlle closer, I was skipping the last step before hitting lock & unlock @ the same time. Oh well, thanks for all the help. Dumb, dumb, dumb!!!!!
Old Jan 26, 2010 | 03:18 PM
evildave's Avatar
evildave
you're doing better than me mate!!! i can't even get the FOB TRAINING menu up
Old Feb 7, 2010 | 04:00 PM
Trog's Avatar
Trog
How long are you having to hold options after getting to the tire training prompt to get it to step forward to the fob training? The 2000 FRC I'm working on just sits on the tire training screen & won't step forward with the options button.
Old Feb 7, 2010 | 05:20 PM
65GGvert's Avatar
65GGvert
Don't hold the options button at that point, press it and release, press and release, to step to fob training.
Old Feb 7, 2010 | 05:44 PM
Trog's Avatar
Trog
tried both... press release & press hold... just doesn't move from the tire train option. unless you press reset of course which takes you into tire train mode.
Old Feb 7, 2010 | 06:17 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
I can't add anymore to what 65GGvert has told you except, make sure your car battery is fully charged. A low battery can affect programming.
To key fob training
