WOT oil consumption
Old Feb 1, 2010 | 09:34 PM
docohm's Avatar
docohm
Default WOT oil consumption
I usually get 5000+ miles per quart on my 2001 Coupe, however, if I hit WOT a few times (which is hard NOT to do) it goes down to 3000 miles or even less. I've changed the PCV valve. Any idea why it's doing this? It all started when I put Amsoil in it instead of the usual Mobil 1. Now it's back to M1 and still doing it.
Old Feb 2, 2010 | 12:19 AM
Blown 346's Avatar
Blown 346
Do you notice less oil, as its low on the dip stick? or is it that your computer tells you to change it earlier than normal?
If your not showing that your car is burning oil, I doubt you are having an issue with oil consumption.
Old Feb 2, 2010 | 07:34 AM
docohm's Avatar
docohm
The 'low oil' message comes up on the DIC. It always take a full quart to get it back to the normal level. No leaks on the driveway, it's getting burned.
Old Feb 2, 2010 | 08:14 AM
craig04c5's Avatar
craig04c5
Originally Posted by 8VETTE7
Common issue on these cars. Get yourself an oil catch can and install it. At least you can catch the oil before it gets sucked into the intake mucking it all up. Do a search on the forum for "oil catch can" and you can learn all about what they do and why they are necessary.
Yep, just checked my catch can last weekend and got about 1/2 pint in 2k miles. I don't race but do some high rpm bursts. I have the Elite Engineering can and it was full.
Old Feb 2, 2010 | 03:53 PM
nextime's Avatar
nextime
Funny on my 2001 I burn oil like crazy at WOT however there is no oil in my catch can.
Old Feb 2, 2010 | 06:04 PM
Blown 346's Avatar
Blown 346
The only fix is to replace the rings.
Old Feb 2, 2010 | 06:21 PM
CleteZ16's Avatar
CleteZ16
St. Jude Donor '09
I disagree; he may be losing oil from the valve seals instead of (or as well from) the rings.
However, an "oil low" message from the DIC shortly after topping off - even after auto-xing - I think you're burning waaaaay too much oil. A little should be expected with temps 330+ and revs past 5k..
An experienced mechanic with a compression tester should be able to see if its losing seal on the compression or power strokes. If there's differences, it's a valve; if not, it's the rings.
Course, I'm a computer professional and not an experienced mechanic, but that's the way I'd go
$.02
Old Feb 2, 2010 | 09:58 PM
tsts's Avatar
tsts
uh oh! I'd better check mine, its been awhile. Had been checking it at oil changes only.
Old Feb 3, 2010 | 08:47 AM
Blown 346's Avatar
Blown 346
$.02
I was baseing my opinion on the 01's as alot of them have ring issues. The only fix for that is to replace them. If it were valve seasl you would see the car smoking a decnt amount at start up.
Old Feb 3, 2010 | 09:46 AM
99 vett babycar's Avatar
99 vett babycar
Old Feb 3, 2010 | 09:54 AM
dankhts's Avatar
dankhts
I found that when I made a dozen or so passes at the strip 2 or 3 times in a month, I'd use a bit of oil, maybe a qt, but last season though, after my mods - heads/cam, etc etc, no more oil consumption at all - even after a couple of track nights and a few dozen passes at the drag strip - must have been weak valve seals in the origional stock heads...after all, my vette is 8 yrs old.. but from what I understand, '01 models are known for piston ring problems...
Old Feb 3, 2010 | 10:06 PM
docohm's Avatar
docohm
$.02
No, it doesn't give me the 'oil low' message shortly after topping off, I can go 2 or 3,000 miles before it wants another quart. And that's only if I hit WOT several times during that period. If I play nice I think it would go longer but not sure, I can't play that nice. Not that I'm drag racing or anything, just 'feel the need for speed' once in awhile.
The '01 is know for piston ring problems? Really? Hadn't heard that, guess I better do some more research...
Thanks...
Old Feb 5, 2010 | 07:13 AM
ZZ06's Avatar
ZZ06
hmmm i thought maybe ring flutter but if your low oil light is coming on then your burning more than "ususal". i use that term loosely bc i have an 01Z and they are prone to this sort of thing. I usually add a quart between changes. I have never gotten the low oil light.
Old Feb 5, 2010 | 09:26 AM
dieseldave56's Avatar
dieseldave56
Default Get you're ducks in a row........
Read my post #18 in this recent CF thread .http://forums.corvetteforum.com/c5-z...-question.html The oil consumption issue affected all LSx engines (particulary those with manual transmissions) from 1999-2002. The LS1 had the same basic cause but not to the extent that an LS6 could* ( could means that oil consumption varied widely for reasons of driving style i.e. aggressive , high rpm with low MAP , ect.)http://forums.corvetteforum.com/c5-t...questions.html
Read post #18 an learn facts & not rumor or misinformation.
Old Feb 5, 2010 | 10:29 PM
docohm's Avatar
docohm
Thanks for the great post and info! I guess since I'm going 2 or 3,000 before adding a quart I shouldn't complain! GM thinks a problem is when you go 400-600!!!! Maybe I can stay under 3200 RPM most of the time...
Old Feb 5, 2010 | 11:07 PM
gleds's Avatar
gleds
Good luck keeping her corraled. I say burn baby burn!
Old Feb 5, 2010 | 11:28 PM
nextime's Avatar
nextime
Still 3 quarts in 5000 miles is very excessive to me, I never had one car burn oil like this except a 69 Chevelle with bad valve seats.
GM says lots of things are OK that we dont agree with!
To WOT oil consumption
Old Feb 6, 2010 | 09:03 AM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
As mentioned above, oil blow-by of the rings is pretty common to LSx engines, particularly at sustained high rpm low load conditions. Likely increasing ring wear as the engine ages allowing more oil to blow by the rings and out the back of the car is not helping. Does your rear fascia have oil mist on it after extended high rpm driving? Mine always did.
This is one of the reasons most of the guys I race with in the SCCA T1 class drop in a new crate motor every year.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Feb 6, 2010 | 05:58 PM
VET-005's Avatar
VET-005
Do a compression and leak down test on each cylinder and that will tell you if your rings are the problem.
Most guys who build race engines and track them change the rings once they get to about 5 to 6% leakdown as you will start losing peak HP and notice oil blowby.
Old Feb 6, 2010 | 06:11 PM
Bill Dearborn's Avatar
Bill Dearborn
There is nothing wrong with your car. Even 3K miles per quart is not bad. There isn't anything wrong with your rings, valve seals, PCV or any other thing. LS engines will use about a half quart to a full quart per day of heavy track driving where you are at WOT for 20 to 30 minutes at a time. That is about 200 miles per quart. Using a catch can will not stop the useage. Go out and enjoy your car there isn't anything to worry about.
The back of my cars were always covered with the thin film of oil that Subdriver mentions except when the thin film was covered with thick wet power steering fluid from blowing a power steering pump on the track.
Bill
