Lifter failure
Old Jan 25, 2010 | 10:19 PM
KLLRVET's Avatar
KLLRVET
Default Lifter failure
My friend recently purchased a 1999 coupe. the car has a little over 100k on it. The exhaust lifter on #1 has started giving him trouble.
Do early LS1's have any trouble with lifters?
Old Jan 25, 2010 | 10:21 PM
lucky131969's Avatar
lucky131969
Not that I'm aware of. What leads him to believe it's a lifter?
Old Jan 25, 2010 | 10:28 PM
KLLRVET's Avatar
KLLRVET
pulled the valve cover to verify. it is for sure the #1 exhaust lifter.
Old Jan 26, 2010 | 01:33 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Are you sure its not a broken valve spring? Lifters will wear out but not till much farther on in mileage but I'm not saying it won't happen. It might simply be a bad one. It'll require the top end taken down and head removal to do the job. I strongly suggest that your friend replace all of the lifters at the same time. If the one lifter has damaged the pushrod, then replace it or all of them. He'll need an upper-end gasket set, torque wrech and the manuals for all the torque values. Its an involved job but can be done. Coolant comes out of course, oil and so on before taking things apart. Be prepared to do the full job carefully and correctly. No shortcuts allowed. New set of head bolts as they are a one time use only bolts or use ARP head bolts. One hint I'll throw in here now, make sure the headbolt holes have no coolant in them BEFORE he goes to put the heads back on otherwise he'll crack the block. I used a shop-vac and modified straw type arrangement on it to make sure the holes on mine were clear of all fluids. Torquing of the headbolts is done by degrees, not foot pounds as you would expect except for the first pass which is done by ftlbs. Anyway, its best if he gathers all the parts needed in advance so he's got everything there and ready to go. Lastly, tell your friend to not drive the car if this lifter has failed totally as he'll only create more damage and a more costly repair.
Old Jan 26, 2010 | 05:17 AM
vettenuts's Avatar
vettenuts
I would check the usual suspects first. Rocker that has lost bearings, broken valve spring or bent pushrod. These are relatively common issues.
Old Jan 26, 2010 | 07:31 AM
KLLRVET's Avatar
KLLRVET
IT IS THE LIFTER. You can back off the rocker, and plunger the lifter pretty easily compared to the others.
The motor was freshened recently, and I bet some debris got into the lifter.
I was just wondering if the lifters are an issue on these motors, or if it may be something else that caused it.
The plans for the repair include:
The GMPP LS1/2/6/7 lifters
A LG G5x3 cam
Patriot LS6 CNC's heads
LS6 intake
Underdrive pulley
Related gaskets and bolts (yes new head and crank pulley bolts
Good pushrods
Old Jan 26, 2010 | 08:19 AM
tail_lights's Avatar
tail_lights
Not usually.
Were the stock lifers put back in the refreshed motor?
I think the LS7 lifters are the way to go, but not 100% sure, good luck!
Old Jan 26, 2010 | 09:09 AM
dankhts's Avatar
dankhts
I had a lifter go bad on my '02, collapsed and wouldn't pump up for some strange reason, luck of the draw, replaced them all with LS7 units, and then went the engine mod route since I had it all apart... heads/cam, etc etc...
Old Jan 26, 2010 | 09:21 AM
USNGoat's Avatar
USNGoat
I've got an LS2 (GTO) that's getting ready to be torn down due to an unidentifiable misfire...
After checking everything out, it has to be something in the drivetrain. Valvesprings looked good, and there was no play in the rocker arms.
This leads me to believe it's either a bad lifter or a failed camshaft. The best part of all this is my car has 40,8xx miles on it
Old Jan 26, 2010 | 12:19 PM
vettenuts's Avatar
vettenuts
That is new information. I have found no matter how clean you are when you work it is very easy to get dirt in the lifter oil gallery.
Old Jan 26, 2010 | 02:56 PM
voda1's Avatar
voda1
Keeping the lifters in the block until the bolt holes and deck surface are clean would go a long ways in keeping gallery clean.
Old Feb 2, 2010 | 05:21 PM
Rconce01's Avatar
Rconce01
Look at my lifter. the roller is flat!!! and yes the rod was bent.
#38
http://forums.corvetteforum.com/c5-t...-ls-1-a-2.html
To Lifter failure
